Go Back   ninjette.org > General > Off-Topic
Old October 12th, 2011, 11:24 AM   #1
headshrink
headshrink's Avatar
555 timer question
A while ago I built a "call light" system in my office. The original project is discussed here: http://www.ninjette.org/forums/showt...atching+switch
Now I was thinking about upgrading (just for fun).
I want to add a reset button in my office, so I have the option of turning the light off remotely, as opposed to the main panel. I do NOT want to use 3-way switches (that would be too easy). Since I want to have an LED indicator on the main panel, to show when the load (light in my office) is on, I figured I would use a momentary switch, and learn some stuff.
I have a 555 timer, and was wondering if this could be used as a basic latching circuit: Press momentary switch (light goes, and stays, on), Press switch again (light turns off). Ideally I don't want the switch on the main panel to serve solely as the trigger, as I want it to have re-set capability as well. The remote switch in my office would be the same.
I have done a lot of googling, but have not found any answers that I understand. Any experts mind helping me out on this?
I can follow directions, but my understanding of electronics, theory, math, is crap. So any replies may have to be dumbed down a bit.
Old October 12th, 2011, 12:17 PM   #2
you could do it but i think you may be over complicating things... you should be able to get away with simply a timer cap tied to ground some resistors and transistors to build the latch... you could even use an inverter with a tied down timer cap and a latched set of trans to handle switching...
Old October 12th, 2011, 03:55 PM   #3
headshrink
headshrink's Avatar
I have no idea what any of that means.
Should I just go with mechanical relays?
Old October 12th, 2011, 05:35 PM   #4
Apex
Livin' the Minimoto Life
Apex's Avatar
Do the easy route then.
Old October 13th, 2011, 10:22 AM   #5
HKr1
IC2(SW)
HKr1's Avatar
Bistable flip/flop is kinda what you want?
scroll down to bottom:
http://www.kpsec.freeuk.com/555timer.htm#monostable
theres the on/off with relays too:
http://www.the12volt.com/relays/page5.asp#lsp
Old October 13th, 2011, 12:11 PM   #6
headshrink
headshrink's Avatar
I think so, although in my reading, the bistable will return to off after a delay.... which I wouldn't want it to do.
The relay example sure has a lot of relays... I'm pretty sure I say examples with one or two relays out there... will keep looking.
EDIT: The one with the trigger and the reset button would work, except I need the trigger button to also work as a reset.... I'm assuming that this circuit wouldn't do that, am I wrong?
Old October 15th, 2011, 12:57 PM   #7
headshrink
headshrink's Avatar
This is EXACTLY what I want to do.
http://www.electronics-lab.com/proje...012/index.html
Now to see if I can make that from RS parts..... with virtually no electronics background.
Old October 15th, 2011, 06:43 PM   #8
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Have you considered using an Arduino? They're super cheap nowadays on ebay, well documented, the programming is so easy even a caveman could do it (uses a very stripped down version of C) and the community support is in some ways better than here for the Ninjette.
Old October 15th, 2011, 09:06 PM   #9
headshrink
headshrink's Avatar
Never heard of it.... just googled it, and it does look like a good option.
I ended up building this version: http://todbot.com/blog/2010/01/02/mo...gle-using-555/
But, unfortunately, it didn't work reliably. So, I gave up and bought 3-way switches from HD, and am adding LEDs as pilot lights for the main panel. At least this gives it a more finished look than the DIY stuff I had been doing.
continuous lap timer plus color coded downloads slolee Ninjettes At Speed 8 February 27th, 2013 11:17 AM
Riding in the Canyons - first timer Skid Riding Skills 31 July 15th, 2012 08:38 PM
First timer from Chicagoland! linkinpark9812 New Members 10 May 13th, 2012 05:43 AM
[motorcyclistonline] - Starlane GPS-2 Lap Timer Ninjette Newsbot Motorcycling News 0 February 12th, 2011 07:30 AM
[motorcyclistonline] - XT Racing Ultra Lap Timer Ninjette Newsbot Motorcycling News 0 July 15th, 2009 02:20 PM
