Old April 29th, 2010, 12:14 AM   #1
leesic66
Motorcycle(s): 2005 Ninja 250
sputtering at 7.5k RPM
Hi! so I was on the freeway tonight and when I tried going over 7.5k rpm it started to sputter. It only started doing this tonight. Also some a-hole tore a hole in the side of my muffler >:O could this have anything to do with it?? Please help!!!
leesic66 is offline   Reply With Quote
Old April 29th, 2010, 01:27 AM   #2
did your bike sputter before you had a hole in the muffler? does the bike continue past 7.5K w/o problems?
Old April 29th, 2010, 01:30 AM   #3
leesic66
nope no sputtering before my muffler mishap. I rode it jus a lil while ago and it has a hard time gettin past 7.5-8k I got it to 10k but was still sputtering and it wasnt going as fast as it should have. I was goin like 78mph at 10k
Old April 29th, 2010, 03:02 AM   #4
can you post a pic of the hole in the muffler?
perhaps a quick fix with some aluminum tape to seal the hole can tell you if it's the cause of the sputtering.
Old April 29th, 2010, 09:16 AM   #5
leesic66
yeah im gonna try to plug the hole today. I still havent had my valves adjusted yet. Do U think that could be the cause of it?
Old April 29th, 2010, 11:50 AM   #6
it might... but I would suspect the hole in the muffler if this started right after that happened. always start w/ the easiest fix first.
btw, how many miles since the last valve adjustment?
Old April 29th, 2010, 12:20 PM   #7
leesic66
lol i dont know! it has like 16k overall. Its an 05. The PO had let it sit from JAn. - April and I dont think ANY service was done on it. I am takin it to Rev Tek tomorrow for valve adjustment and CCT replacement. Cuz there is a clacking noise coming from the tp of the engine on the right hand side.
Old April 30th, 2010, 03:07 AM   #8
leesic66
Question
I was thinkin that maybe Im lean. I dont have backfire but its like not enough gas is goin in for that kind of RPM....IDk
Old April 30th, 2010, 05:11 AM   #9
drstimpy
two wheels good
drstimpy's Avatar
Motorcycle(s): 04 ex250 and 08 Triumph Sprint ST and custom calfee carbon race tandem
Interesting to see what happens when you plug the hole. Might have leaned up a bit with the accidently freer flowing exhaust?
Some must watch while others must sleep
drstimpy is offline   Reply With Quote
Old April 30th, 2010, 09:37 AM   #10
leesic66
would it still be lean even after I plugged the hole?? I did that yesterday and its still lagging once I reach 68mph and above.
Old May 15th, 2010, 09:52 PM   #11
HotWheels
Motorcycle(s): EX 250
Carb clean
Hey there. I didin't think the hole was the culprit originally when reading it how ever I was suspicious. Since you've plugged the hole and are still getting ill effects, the next thing I would jump on would be a thorough carb cleaning assault with a small copper wire in hand as well. 7.5 is right about where the biggest part of the main jet comes into play how ever it does affect everything below it as well. These carbs can get get a little tacky in there so easily...=/
When rejetting for my Muzzy, that was where the hard cold/warmed up acceleration took place to determin the proper main jet size. Mine have been clogged a couple times. Grab some carb cleaner and some 18 gauge copper wire and declare war.
HotWheels is offline   Reply With Quote
Old June 2nd, 2010, 11:03 PM   #12
JBar215
JBar215's Avatar
Motorcycle(s): 2005 Ninja EX250, 2005 SV650S
I have an 2005 with the same clacking issue but not the sputtering at all but it does idle a little rough. any help on this? Do i need to adjust the valves?
JBar215 is offline   Reply With Quote
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
2010 Ninja 250 Tach/sputtering problem wyciwug 2008 - 2012 Ninja 250R Tech Talk 3 May 16th, 2014 09:38 AM
Sputtering at high RPMs Malicious Logic 2008 - 2012 Ninja 250R Tech Talk 24 July 10th, 2012 02:41 PM
Sputtering and no speed totaled 2008 - 2012 Ninja 250R Tech Talk 5 September 20th, 2011 08:19 AM
Sputtering in powerband? Tentil3 1986 - 2007 Ninja 250R Tech Talk 5 October 15th, 2009 09:28 AM
