Old February 22nd, 2013, 06:20 AM   #1
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Wheel Alignment
My DRIIs were mounted last night. When I put my back wheel back on, set the chain tension, and checked the alignment of the hash marks, my right chain adjuster plate w still loose. Before I removed my wheel, both sides had 8 threads exposed. Now, my chain side is still at 8 threads, but I had to tighten the right side to 9 threads to snug the plate to the swing arm again. Did I do something wrong, or is it the facts of life?
I also found out the front and rear axle use two different sizes of cotter pins. Have to buy a new box for the front now. First world problems...
geeker is offline   Reply With Quote
Old February 22nd, 2013, 06:32 AM   #2
You should not have changed the original adjustment.
All you have to is pushing the tire all the way forward before and during torquing the shaft.
Old February 22nd, 2013, 06:35 AM   #3
geeker
geeker's Avatar
It looked off center when I did that. At least I know it was only one turn in. I can work on it again tonight after work.
Old February 22nd, 2013, 11:02 AM   #4
Those marks are not to be trusted; they are just an indication of the shaft is at in its range of movement.
This is the proper way to a wheel aligment:
http://www.ninjette.org/forums/showp...2&postcount=23
Rear wheel alignment SwagenGTI 2008 - 2012 Ninja 250R Tech Talk 23 April 7th, 2013 09:51 AM
Wheel alignment? jack_bm 2008 - 2012 Ninja 250R Tech Talk 2 June 1st, 2012 03:56 PM
Rear Wheel Alignment Gorilla25 2008 - 2012 Ninja 250R Tech Talk 16 September 27th, 2011 11:38 AM
rear wheel alignment tool quanttrom 2008 - 2012 Ninja 250R Tech Talk 11 September 3rd, 2011 10:03 PM
wheel alignment eddiekay 2008 - 2012 Ninja 250R Tech Talk 1 February 20th, 2010 11:52 AM
