Old July 15th, 2012, 06:49 AM   #1
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
Front tire at 13 psi but cracked
ok so the title says it all, i was cruising around in the forum when i saw a thread that reminded me to check my tire pressure, the back tire is at 32 psi but the front is at a insane 13 psi. the thing that has me sweating bullets is the fact that the side walls of my front tire have small cracks in it
im afraid that if i fill the tire to the correct psi it might pop any advise would help tons!
thanks guys.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old July 15th, 2012, 07:08 AM   #2
Reyno2ac
Reyno2ac's Avatar
Motorcycle(s): Red 2009 Ninja 650r
How old is the tire?
If you're worried, replace the tire. Remember, you only have one other tire to stand on when this one goes, not three.
Reyno2ac is offline   Reply With Quote
Old July 15th, 2012, 07:09 AM   #3
Surface cracking on the sidewall of a tire isn't that uncommon as they age, and often isn't a sign of impending doom. But - it does mean the tires are starting to get a bit old, and can be a reason to think about changing them out even if there is some tread left. How old are the tires? There is a 4 digit date code on the sidewall, the last two digits are the year of manufacture, and the first two digits are the week of that year. Either way, it's unsafe to be riding around on a front tire with 13 psi.
Old July 15th, 2012, 07:26 AM   #4
7oxSin
MSF Coach!
7oxSin's Avatar
lol... the tire says 1502 so it looks like these where the tires that came on the bike when it was sold? tons of tread and the bike only has 7k miles on it. but i have had it for a little over a month now ive put a good 600 miles on it since i got it.
Old July 15th, 2012, 07:39 AM   #5
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
Don't worry about a thing. They're fine. It won't explode. Especially at 32psi with how thick motorcycle tires are. The tires on my BMX bike used to have to be filled to 120psi. Those were fun when they exploded!
As previously said, I'd think about replacing them in the future. Mine had 3k miles on them when I got them, but they were also twelve years old. The tread is in great shape, but there is cracking even worse on my tires, but not too severe. It passed MA state inspection! The tires still offer as much grip as the crap stock ones can, but I figured I'd ride them for this season before throwing away some okay shape tires.
Even worse were the original ones from my 1982 CB450. Even those 30 year old tires passed MA inspection! I know those shouldn't have at all. One cool evening when the road was slightly moist I was out and about accelerating up a left uphill from a stop. When I took off the rear end began washing out and I got a of wheel spin. This was no big deal to me as I had rode dirt bikes for 13 years before this. In fact, I found it fun and kept the wheel spin going all the way up the hill, imagining I was blasting out of a huge loamy berm roosting other riders behind me haha. To someone not used to the bike reacting like that, they might have found themselves in a low side or high side crash situation.
dirty nasty is offline   Reply With Quote
Old July 15th, 2012, 07:50 AM   #6
Get new tires. They don't have great grip when new, and at 5 years are marginal. At 10+ years, they are serving as rim protectors, and not much else.
http://www.ninjette.org/wiki/Tire_options_-_pregens
and
http://faq.ninja250.org/wiki/What_ti...fit_the_250%3F
Old July 15th, 2012, 07:51 AM   #7
7oxSin
MSF Coach!
7oxSin's Avatar
yeah i have lost a back wheel out from under me, but not on this bike. thanks im going to fill em up right now whats the best psi for front and back tires? they just say weight limits at 40 psi on the tire.
Old July 15th, 2012, 07:56 AM   #8
28 front / 32 rear is a good starting point. But even at optimal pressures, the tires are miles off what a good quality newer set will feel like.
Old July 15th, 2012, 08:31 AM   #9
dirty nasty
I don't think the stock tires are THAT bad. They're nothing great, but I wouldn't call mine rim protectors either, nor would I even call them marginal.
Who knows, maybe I'm ignorant of the world of fresh tires.
Old July 15th, 2012, 08:43 AM   #10
Yes.
Old July 15th, 2012, 10:21 AM   #11
7oxSin
MSF Coach!
7oxSin's Avatar
these tires are Bridgestone Spitfire Touring tires in size 100/90-16 so i dont think they where stock.
Last futzed with by 7oxSin; July 15th, 2012 at 10:25 AM. Reason: added pic
Old July 15th, 2012, 10:54 AM   #12
You are correct.
As explained above, the cracks are only on the rubber film that covers the mesh that actually holds the pressure.
Rubber alone is not rigid and strong enough as to hold either the pressure or the shape of the tire.
Rolling the tire at low pressure flexes that film (already hardened due to age) much, generating lines of fracture.
Inflate them up to the recommended pressures and check the front one for leaks (spraying soapy water all over it).
Then, order new tires and learn how to remove and install these tires.
Read this article about what is inside these tires:
http://www.sportrider.com/tech/tires...res/index.html
The danger of under-pressure is that the tire and the air inside can heat up so much during a long trip that can make the tire blow up.
Old July 15th, 2012, 01:15 PM   #13
i need to finish reading replies more often
Old July 15th, 2012, 01:18 PM   #14
7oxSin
MSF Coach!
7oxSin's Avatar
lol
and tires are now inflated to the right psi, after i super inflated my front one cuz i had my air compressor set too high. now i need to ride it and test it out.
Old July 15th, 2012, 01:21 PM   #15
just my personal opinion here. i think if the side walls are cracked it communicates that the rubber is dry. it wont stick very well at all. especially in the wet. me personally- i would replace them both being that old.
Old July 16th, 2012, 03:30 AM   #16
dirty nasty
If could couldn't figure out that the pressure needed to be increased, then you've got no business being near a bike. C'mon, quit trollin'.
Old July 16th, 2012, 07:07 AM   #17
7oxSin
MSF Coach!
7oxSin's Avatar
If you are talking to me then you need to read the thread before you troll. The thread is about if its safe to fill the tire with the cracks, I have had a tire blow up in my face off a car, so I thought I would ask the forum since MOST of the people here are smart, nice, and awesome.
Posted via Mobile Device
Old July 16th, 2012, 07:57 AM   #18
but i like trolling?
Old July 16th, 2012, 08:34 AM   #19
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
they see him trollin'...they hatin'..!!
Miles_Prower is offline   Reply With Quote
Old July 16th, 2012, 09:48 AM   #20
Old Lemon
Lays er down
Old Lemon's Avatar
Motorcycle(s): 2008 Lime green Ninja 250R
Don't trust him, he's wrong
Old Lemon is offline   Reply With Quote
Old July 16th, 2012, 11:06 AM   #21
they see me trollin', they hatin'. drivin' carolla, been tryin'ta catch me writing wordy.
tryin'ta catch me writing wordy (tryin'ta catch me writing wordy)
my exhaust is so loud. im squiddin'! they hopin they gon catch catch my writing wordy!
Police think they can see me lean
Im pint sized- aint easy to be seen.
When they see me ride by they see that glean
and my whine on the blacktop and the oil screen.
ride with a squid chick, she like hold up
next to the mechanix gloves is a half helmet and my mowhawkaah
turn a cager into a killer
girl you aint know, im crazy like ghost rider
just tryin to ride her aint tryin to have no babies.
bike dont clean itsself, i pull in ladies
laws of trollin, you know they hate me.
exhaust turned all the way up until the maximum
i can speak for some squiddeis tryin to race for some
but we packin dick, and we have... umm...
ill get locked up for doin the maximum.
GMR is hell, I'm grippin choke
exhaust loud, and my ass is rippin slow.
"twist and twistin" like im not slow.
Police pull up from behind and is in his throat
Windows down gotta stop pollution
MCs change people like who is that burnin out.
This the Play-N-Skillz when we out and cruisin
Got warrants in every city except Houston but I'm still ain't losin
Old July 16th, 2012, 11:30 AM   #22
Miles_Prower
One Loyal Fox
WOW.
how long did that take..or did you just lil wayne it? lol
Old July 16th, 2012, 11:32 AM   #23
just call me big-waynge
Old July 16th, 2012, 03:54 PM   #24
If it was 13PSI, I'd wonder if there's something else you're missing that caused it to lose all that pressure.
Old July 16th, 2012, 07:30 PM   #25
dirty nasty
Damn. I like it.
cold weather tire PSI professor gascan General Motorcycling Discussion 6 November 12th, 2012 02:41 PM
Cracked Tire BlueHairSar General Motorcycling Discussion 8 September 9th, 2012 05:24 PM
[roadracingworld.com] - Bridgestone: New Spec Front Tire Is Now The Standard Front Ti Ninjette Newsbot Motorcycling News 0 June 12th, 2012 10:20 AM
tire upgrade question: front tire? stryder 2008 - 2012 Ninja 250R Tech Talk 1 April 5th, 2010 07:40 AM
