Old April 17th, 2012, 07:42 AM   #1
xA2D9
xA2D9's Avatar
sprockets and chains
I have been reading around a bit and I may just be missing it but I want to change out my chain and sprockets, I want to go with 15/44 but the whole chain thing is confusing me, I would appreciate a semi dumbed down explaination of the ring types and master links or rivets whats the difference in them whats better for just normal riding just want to avoid grabbing some stuff and it not working together for whatever reason
xA2D9 is offline   Reply With Quote
Old April 17th, 2012, 10:12 AM   #2
RedNinja21
RedNinja21's Avatar
Motorcycle(s): Kawasaki Ninja 250R
Hey, I just finished the same set up with a couple of JT sprockets and DID chain. Below link has lots of good info that can help you along the way:
http://faq.ninja250.org/wiki/What_re..._I_consider%3F
You might check out my previous thread for more info:
http://www.ninjette.org/forums/showthread.php?t=99289
Good luck
RedNinja21 is offline   Reply With Quote
Old April 17th, 2012, 05:44 PM   #3
Don't get too caught up in the ring types. As long as it has rings, you're good, and any ring type other than O-ring is simply a better design meant to seal more lubrication and reduce resistance.
As far as master link types, most people only have the tools to install a clip-type, but rivet is better and less likely to fail. It's probably not a real concern with a 250 anyway. Just make sure to use a master link that is the same size and ring type as the chain which you can install with the tools you have. EK has a screw-type master link that sounds like a good compromise (uses regular tools for a rivet-like installation but costs ~$15 for the link alone).
How long do you go between new chains? agentbad 1986 - 2007 Ninja 250R Tech Talk 13 November 25th, 2014 02:53 PM
All about chains Sirref 2013 - 2017 Ninja 300 Tech Talk 27 September 1st, 2014 10:33 AM
Chains? quadcrazy 2013 - 2017 Ninja 300 Tech Talk 2 January 22nd, 2014 06:03 PM
Chains & Sprockets thisisbenji General Motorcycling Discussion 7 October 23rd, 2013 06:28 PM
Sprockets, sprockets, ahhh sprockets?!?! shelei09 General Motorcycling Discussion 10 January 23rd, 2013 09:47 PM
