Go Back   ninjette.org > General > Off-Topic
Old March 13th, 2011, 09:42 AM   #1
00NissanNinja
I hate driving...
00NissanNinja's Avatar
Motorcycle(s): 13 Triumph Street Triple R, 09 Ninja 250r (Sold 4/20/12)
Is switching from synthetic truly murderous on an engine
I've heard people say it. Is it really all that true, that I do not know. I'm thinking about putting high mileage oil back in my car (this is not dealing with bikes but this question can apply for bikes as well), simply because my car is old and I feel as though the synthetics caused me to have some leakages of oils from the old seals on my car (praying its not the head gasket).
09 ninja 2fiddy SE Driving slow things fast
00NissanNinja is offline   Reply With Quote
Old March 13th, 2011, 09:50 AM   #2
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
I find on old cars you should use reg oil. The older seals seems like they can't handle the syn oils. Unless you started running it early in its life. I have heard that syn oils could shrink seals.?. Not sure if that is true or not. Most my cars are as old as me, so I run reg oil in it.
scotty is offline   Reply With Quote
Old March 13th, 2011, 10:03 AM   #3
00NissanNinja
I hate driving...
Yeah thats what I heard so I'm definitely going back to regular oil. From my experience it seems that statement may be true. Its just that some people say its worse to go from synthetic back to regular.
Old March 13th, 2011, 10:48 AM   #4
Is switching from synthetic truly murderous on an engine ?
no
Old March 13th, 2011, 03:12 PM   #5
rockNroll
rockNroll's Avatar
Motorcycle(s): black
Except for kkim's post, everything in this thread is pretty much false. Synthetic won't cause leaks. It's fine to switch to non synthetic. The cow did, in fact, jump over the moon.
Old March 13th, 2011, 04:16 PM   #6
warlord
warlord's Avatar
Motorcycle(s): 2014 Ducati Panigale 899
Switching from regular to synthetic can worsen leaks depending on the condition of the seals, especially with a high mileage car. Regular oils can hide the fact that your seals are bad because the the sludge reinforces the leaky seal. Switching to a synthetic (which does a good job of removing that gunk) can then cause leaks to reveal themselves.
Once you have leaks then switching back to regular oil, even high mileage oils with seal conditioners, isn't likely to help. You'll need to go through your engine to find the leaks and replace the leaky seals.
Bottom line: synthetic oil didn't cause your seals to leak rather the sludge from using regular oil in your engine was hiding the fact that your seals were bad.
warlord is offline   Reply With Quote
Old March 13th, 2011, 04:18 PM   #7
that is my understanding as well.
Old March 13th, 2011, 04:27 PM   #8
Boom King
So, where's the reverse?
Boom King's Avatar
I think this might have been a problem when synthetics were first produced for consumer automotive use decades ago. The belief was that certain PAO based synthetics would cause plastic car parts made of Polyoxymethylene to become brittle and crack, etc. Not sure if this was ever true or not. Could have been a myth started by rival oil companies for all we know.
I don't use synthetic so I admit I don't follow this debate closely and for the OP I'd be surprised if your leaks were indeed caused by using synthetic oil given modern car manufacturing and modern oil formulations. However, if it makes you feel better, switching to dino oil should be fine as well.
Old March 13th, 2011, 04:58 PM   #9
00NissanNinja
I hate driving...
Yeah I know that. It is just I was talking to this mechanic and he was really adament about it. I felt like that switching it wouldn't do much of anything (and still feel that way). Just curious what most people think. I actually think its just my distributor leaking oil from its seal and seeping everywhere else. Its a very small seepage of oil. Mainly I want to see if someone had some facts to back up the claim/myth its bad to switch from synthetic to regular oil.
Old March 14th, 2011, 05:58 AM   #10
dubojr1
dubojr1's Avatar
Old March 14th, 2011, 06:05 AM   #11
wvninja
wvninja's Avatar
Motorcycle(s): 2009 Honda CBR600RR
Mechanics get set in their ways.
A crazy man can call the sky purple, believe that its purple and assure everyone around them that it's purple. Doesn't mean its true or based around any facts
"Riding a motorcycle is like playing sports, not everyone is cut out for it." - WVNinja
wvninja is offline   Reply With Quote
Old March 14th, 2011, 06:08 AM   #12
dubojr1
dubojr1's Avatar
Sounds more like a mechanic that was looking for an easy way out of a problem he could not explain. Just blame it on the synthetic...
Personally I'd consider other mechanics.
Old March 14th, 2011, 07:01 AM   #13
Flashmonkey
Professional belly dancer
Flashmonkey's Avatar
Motorcycle(s): 1992 GSX-R 750
LOL...winning.
But ya, if you're talking about your bike, switching to syn shouldn't be too much of a problem.
Old March 15th, 2011, 09:32 AM   #14
gfloyd2002
User Title Free Since '12
gfloyd2002's Avatar
MOTM - Feb '12
There is a good reason for OPs question, but that is with old synthetics. New synthetics are fine.
Echoing earlier posts in this thread, early synthetics got a bad reputation for leaking. This was because the seal-swell characteristics of the new synthetics were different from those of the mineral oils they replaced. If the seal-swell rate was lower, the seals shrank and oil leaked from crankshaft seals and rocker cover seals. If the rate was higher, the seals swelled a little extra and the engine was tight. Then if the owner changed back to mineral oil, or added a quart when no synthetic was to be had, things got really bad. The crank seals had become worn, in their turgid state, and then relaxed. The valve cover seals were compressed when swelled, and when the different oil was added, everything leaked.
However, synthetics on the market now have resolved this. You should have no problem switching back and forth.
Old March 15th, 2011, 09:48 AM   #15
00NissanNinja
I hate driving...
Yeah cool, thats what I figured. Seems its my dizzy leaking from what I can see now that I have torn some crap from around it. Its seeping oil along the front of my engine. Guess I'll be fixing that when I get to it. I do all maintenance on my car, just don't want to f it up. I've already fixed so much lol. Thanks for the reassurance
Old March 15th, 2011, 09:55 AM   #16
wvninja
wvninja's Avatar
kkim is "winning the internet"
Old March 17th, 2011, 09:06 AM   #17
trex
Motorcycle(s): 250r '08 Candy Plasma (best) Blue
please go to bobistheoilguy.com for all of your oil needs
this page in particular deals with mineral vs. synthetic
http://www.bobistheoilguy.com/cms/in...=article&id=81
trex is offline   Reply With Quote
Switching to Synthetic sheeb 2008 - 2012 Ninja 250R Tech Talk 11 November 13th, 2013 09:02 AM
synthetic oil vs regular Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 2 September 17th, 2011 09:09 PM
Synthetic Oil: Bad? jonthechron 2008 - 2012 Ninja 250R Farkles 25 August 20th, 2010 05:59 PM
[sportrider - latest stories] - Silkolene Pro 4 Series Synthetic Engine Oil Ninjette Newsbot Motorcycling News 0 April 28th, 2010 11:50 AM
When to go synthetic Betlog 2008 - 2012 Ninja 250R Tech Talk 34 January 15th, 2010 01:05 PM
