Old February 26th, 2012, 05:58 PM   #1
ladyninja08
ladyninja08's Avatar
Motorcycle(s): 2011 black ninja 250r
rear spools
Does anyone know what brand of spools will work with the cheap harbor freight rear stand? Thanks in advance
ladyninja08 is offline   Reply With Quote
Old February 26th, 2012, 06:05 PM   #2
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
It's not what spools will work with the stands, its what spools will work with the bike.
Ninja 250's need 10mm spools.
PS: this is posted in the wrong forum if you have a 2011 bike. You posted in the pre-gen forum. I'm sure it will be moved any moment now. :P
MikeBudd is offline   Reply With Quote
Old February 26th, 2012, 06:12 PM   #3
ladyninja08
Ooops on wrong post location but needed to know which brand spool will fit the fork part of the rear stand .
Old February 26th, 2012, 06:17 PM   #4
MikeBudd
MikeBudd's Avatar
Again, all spools are essentially the same size (unless you buy mini-spools), and will fit all motorcycle stands. All that matters is the size of the bolt which is 10 mm. You buy the spools to fit the bike, not the spools to fit the stand.
Just buy some spools, make sure they are 10mm (before you buy them), whatever brand (or unbranded) you feel comfortable with, then screw them on your bike.
Your stand has to fit the ninja 250's width correctly or else it won't work, getting different spools will not help
Old February 26th, 2012, 06:28 PM   #5
ladyninja08
Okay Thanks mikebudd. I was using a set of t rex spools but it didnt feel like they fit tight into the fork part so I thought I would get a different (smaller) spool for a better fit.
Old February 26th, 2012, 07:24 PM   #6
MikeBudd
MikeBudd's Avatar
You can buy mini spools that are definitely smaller. But other than that, there really isn't anything else.
Old February 26th, 2012, 08:45 PM   #7
/moved the new-gen farkles
SV Racing Parts, 10mm Swing Arm Sliders with Spools for Rear Stands SV Racing Parts Motorcycle-related 0 February 16th, 2015 11:44 PM
How to install Rear Spools on your Kawasaki Ninja 300 Motorcycle & eBay parts review! SON1C 2013 - 2017 Ninja 300 Tech Talk 14 June 27th, 2014 08:15 PM
Rear Spools FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 1 September 11th, 2013 06:13 PM
Yoshimura Rear Spools 08+ Black, New GlassAnkles Motorcycle-related 5 March 7th, 2012 11:40 AM
Installing pitbull rear spools Rafalski 2008 - 2012 Ninja 250R Tech Talk 11 August 26th, 2009 08:00 PM
