April 18th, 2016, 06:27 PM | #41 |
Board Member
how's it coming @bruce71198?
April 19th, 2016, 03:43 PM | #42 | |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
[IMG][/IMG] |
April 19th, 2016, 04:22 PM | #43 |
MOTM - Sep '18, Feb '16
Wow.
That is perfect. Pointy high top pistons are problematic in controlling detonation. Those look fantastic. If the bigger valves hit the cylinder walls you can notch the walls above the ring travel.
April 19th, 2016, 08:23 PM | #44 |
Board Member
What block is that?
April 20th, 2016, 04:42 AM | #45 |
It appears to be an all aluminium block like the ninja 300, but I don't think they made rings that will mate up to a chrome plated block over stock bore?
April 20th, 2016, 09:57 AM | #46 |
April 20th, 2016, 03:06 PM | #47 |
I think I know but will not say.
April 20th, 2016, 03:18 PM | #48 |
Vintage Screwball
MOTM - Mar '16
It's liner-less.....that should tell you everything you need to know.
Goin' fast on slow bikes! |
April 20th, 2016, 04:17 PM | #49 | |
On a serious note, he either had custom rings made, that block is just for a test, or he is doing something wrong.
April 20th, 2016, 04:21 PM | #50 |
April 20th, 2016, 04:22 PM | #51 |
Wait, I forgot he didn't bore the motor over, sorry disregard everything I said about the block or rings above.
April 20th, 2016, 04:34 PM | #52 |
Board Member
April 20th, 2016, 05:03 PM | #53 | |
The stock 250 bore to stroke ratio was 1.5:1, stock 300 is 1.27:1, and your bike is 1.36:1, you a can use this info to help predict the torque curve.
April 20th, 2016, 06:42 PM | #54 |
I thought it was a Kawahana block
April 21st, 2016, 07:55 AM | #55 | |
I used the 3 layer head gasket that came with it on my last engine to help increase the squish and prevent the head gasket failures I was experiencing. It worked. Unable to procure more of these head gaskets I have Cometic making some. Back to the fine print, the pistons are cast not forged and although nicely machined they where soft, heavy and way to tall for the stroked crankshaft. With the amount of material between the top ring groove and piston crown I chucked them up in the lathe and started cutting. When they finally fit the top of the piston was to thin, into the scrap bin they went @Somchai gave me the idea to try ZX6 pistons and rods. The 2010 parts where the closest so with a little modification i'm pretty close to something that may work. Stay "tuned". |
April 21st, 2016, 07:59 AM | #56 | |
April 21st, 2016, 08:08 AM | #57 |
April 21st, 2016, 08:13 AM | #58 |
Was there not enough piston to crank clearance, or was the squish just gigantic? Did you end up milling some off the top of the cylinder? If you did what did you do about cam chain slack (does the CCT make up for it) and the effect on cam timing?
April 21st, 2016, 08:52 AM | #59 |
I'm using the ZX6 piston as well, it clears the crank just fine. Squish is big and can't mill the cylinder block because it will flake the chrome, I'll take what I need off the crank case. I have slotted cam gears to rectify the cam timing issue. Cam chain slack is minimal, not an issue.
April 21st, 2016, 03:38 PM | #60 |
Board Member
Crazy fine print.
I am sticking to 264 but you are tempting me to try 282.... |
April 21st, 2016, 04:06 PM | #61 |
It appears that Wiesco is now recommending bigger sleeves if you are going 4mm over. Mine worked ok but I talked to others that cracked the cylinders at 4mm. You could always throw a 300 crank in yours for 315cc.
April 21st, 2016, 05:19 PM | #62 |
I think somebody just needs to make +4mm rings for chrome liners. Then we could use 300 cylinders. I'd imagine JE or Wiesco would make one if there was some interest and we asked politely.
April 21st, 2016, 05:47 PM | #63 |
Board Member
Millennium technologies will put in different sleeves if you want.....
April 22nd, 2016, 08:45 AM | #64 |
300 cylinders are 62mm. Or are you talking about boring the 300 cylinders and chroming them?
April 22nd, 2016, 09:29 AM | #67 |
Vintage Screwball
MOTM - Mar '16
If you need custom rings and are proficient at measuring end gap, ring width, etc, just call Total Seal. They will custom make, very affordable, any rings you need out of any material you need.
We had to do this for the Venolia slugs we're running in our race bikes. No one makes rings for them any more..... http://www.totalseal.com/
April 22nd, 2016, 09:38 AM | #68 | |
April 22nd, 2016, 09:41 AM | #69 | ||
Vintage Screwball
MOTM - Mar '16
http://www.racetep.com/totalsealframe.html Quote:
April 22nd, 2016, 09:58 AM | #70 | |
Board Member
April 22nd, 2016, 10:16 AM | #71 |
Board Member
I called total seal and asked about my 64mm application.....no dice.
April 22nd, 2016, 10:19 AM | #72 | |
Vintage Screwball
MOTM - Mar '16
We called them and just gave them ring specs (Thickness, end gap, ring width, etc) and the materials we wanted. POOF! Done. Did they say why?
April 22nd, 2016, 10:27 AM | #73 | |
Board Member
To qualify: they can do this, but it needs to be a 1000 piece minimum order. |
April 22nd, 2016, 10:28 AM | #74 |
Vintage Screwball
MOTM - Mar '16
Ah, that makes more sense. Thanks!
May 22nd, 2016, 06:37 PM | #75 |
Board Member
any updates Bruce?
May 24th, 2016, 12:21 PM | #76 |
Soon, I had to build a 2mm, 300 crank engine for a guy (315cc), ported stock valve head, tighted up the squish. Runs real strong, I want to get it on the dyno and see what it does. After that build I got back into my SV engine (2 of them) then Moto America started up, so I've been real busy.
May 24th, 2016, 06:50 PM | #77 |
Board Member
K. Thanks for the update.
May 24th, 2016, 07:02 PM | #78 |
Urban Legend
Join Date: Apr 2014 Motorcycle(s): 09 Ninja 250R SE - Circe Posts: 542
"Life is like riding - You can either tear the fastlane in half or stay in the slipstream trying to play catch up." -Baron |
May 29th, 2016, 06:53 AM | #79 |
48hp out of a 250? Hahahaha! That's called a grenade!
May 29th, 2016, 07:21 AM | #80 |
Board Member
While he started with a 250, Bruce is investigating the 300+ cc range to get this amount of HP.
So far, he has been pretty successful. |
Idle shooting WAAY up on start | Alchemist | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 13th, 2014 01:36 PM |
Connecticut school shooting | OCMagnum | Off-Topic | 183 | December 19th, 2012 11:32 AM |
RE: Theater Shooting... | Countersteer | Off-Topic | 94 | July 31st, 2012 06:20 PM |
Trouble Shooting a couple things | x only performance | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 18th, 2012 03:48 AM |
The shooting of Somali pirates | HKr1 | Off-Topic | 5 | December 30th, 2010 05:12 PM |
