December 22nd, 2013, 01:13 PM | #1 |
MOTM - Sep '18, Feb '16
2007 ninja won't run? what to do.
OK. A very dear old friend brought me his son in laws bike. Its a 2007 and was ridden daily from 1200 miles when he got it . To 15000 miles it has now.
He called a year ago and said it was running poorly. I said pilot jets . But just a guess. He took it to a number of shops. They all fiddled around and gave it back. By the time I got it. Hauled from another state. It would not start. First thing I do is a compression test. 30 left 80 right. You need a min 125 psi cold or the engine will not start. I pulled the head and checked the valves. Adjustment was good. And the seal of the valves was tight. but carbon was built up all over the intake valves. The cylinder looked glazed and there was carbon on top of the piston. I pulled the carb off and sure enough the pilot jets are clogged and the idle screws are three turns out. The problem started with the carb. But ended with a some what bad engine. He is very good about oil changes . That saved the bottom end. But I am going to replace the pistons and rings. And hone the cylinder. Next I will rebuild the head with new valves and valve stem seals Then replace the carb pilot and main jets. After assembly with new gaskets a new cam chain tensioner and fresh oil I will balance the carbs. Total cost of the parts from cheap cycle parts was under 300 bucks. Plus the jets and valves. The whole package is less than 500 in parts. Not bad for an old bike. Should run great when its done.
December 22nd, 2013, 01:53 PM | #2 |
Can someone help me out. I never use factory parts. JE pistons.
The rings from Kawasaki are marked R on the silver one. And NR on the black one. I can't find my first gen manual. Can anyone tell me which ring goes on top.
December 22nd, 2013, 05:23 PM | #3 |
I found my service manual and assembled the bottom end. Now just some head work left to do.
December 23rd, 2013, 11:31 AM | #4 |
Nice work.
December 23rd, 2013, 12:26 PM | #5 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
Ok, the uninformed need to know. Which ring goes where? My intuition says that if neither ring is obviously a scraper ring, the silvery (Moly or Chrome) would go on top, with the black (Iron or iron/moly) on the bottom.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
2009 Ninja 250 won't run | Matto55 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 3rd, 2014 03:05 PM |
ninja 250 won't run video included | possession | 2008 - 2012 Ninja 250R Tech Talk | 17 | April 14th, 2014 06:50 AM |
2007 Ninja 250 won't start | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 24 | June 17th, 2013 10:14 PM |
Won't "run right", won't idle, choke only, etc?? - SOLUTION HERE | Jiggyfly | 2008 - 2012 Ninja 250R Tech Talk | 5 | May 16th, 2012 09:50 AM |
2007 250 Won't Start | mveezy | 1986 - 2007 Ninja 250R Tech Talk | 16 | June 28th, 2009 06:24 PM |
