September 9th, 2017, 05:15 PM | #1 |
Ninja 250r Noob
Join Date: Jul 2017 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 77
Turn Indicator Wiring Help?
Hello there everyone!
Here's the scoop: Left front signal bulb and cover broke during a move. Bought some flush mounts for now till I get some OEMs. I am unsure of how to connect the wiring. I purchased the bike used with flush mounts already on it. They had connected an OEM connector to the wires if these after market lights. Is it so, that all I must do is connect red to green...then black to black/yellow? Do I just rip the bullet connectors off and twist the wires together?
"Kawasaki Ninjas Rule!" - 1997 Power Wheels Commercial |
September 9th, 2017, 05:39 PM | #2 |
If you're not going to install matching bullet connectors, then make nice solder joints and use heat shrink tubing to insulate them.
September 9th, 2017, 05:44 PM | #3 |
Ninja 250r Noob
I have never done electrical before, I apologize lol. What doyou mean by "matching bullet connectors"?
Would it be possible just to clip, strip and rwist together?
September 9th, 2017, 07:10 PM | #4 |
Join Date: Jun 2017 Motorcycle(s): 2011 Ninja 250r se Posts: 100
Yeah you *could* cut and strip and twist but it will make it a **** when you need to take the bike apart which you will end up doing. Bullet connectors are cylindrical electrical connector pair for wiring. Male / female.
They should give me my own section called kik rox is a silly **** who breaks stuff. |
September 9th, 2017, 07:28 PM | #5 |
Ninja 250r Noob
My wish is to splice the flushmount signal into the OEM connector to plug into the other OEM connector on the bike. I dont feel that would hinder my ability to take the bike apart. I should be getting new OEM ones at some point here soon and was wondering if I can just twist the wires together and tape the connection well? Or is that just dumb?
September 9th, 2017, 07:40 PM | #6 |
The honest answer is that it's dumb. As I posted above, solder and heat shrink for reliability. Or get a kit of the right sized Japenese bullet connectors and use those. Twisted wires is not something you want on a motorcycle.
September 9th, 2017, 07:52 PM | #7 |
Ninja 250r Noob
Alright! I'll solder them up! Thanks again guys!
September 9th, 2017, 08:44 PM | #8 |
Your best long-term solution is to cut off the wires from the busted flush-mount to recover OEM conector. Then re-use them on new lights. Here's how to butt-solder two wire-ends together.
September 10th, 2017, 11:17 AM | #9 |
In anything, however I must admit that my signals got twisted and taped back together after my integrated tail light took a dump. I *could* do it right but meh... Later....
September 10th, 2017, 03:53 PM | #10 |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
When I bought my pre-gen in March the turn signal connectors were messed-up from a previous accident/owner. I installed a connector used for wiring trailer lights on a car. It's got a male and female connector on one connector and the same on the other connector. It's good and solid and more durable than the OEM bullet connectors. I did this for both turn signals.
YES! Solder and shrink tube the connectors please. Bill
Insanity: doing the same thing over and over again expecting different results each time. |
September 10th, 2017, 08:15 PM | #11 |
Also note that you've got 2-way lights while factory light and busted one is 1-way. You'll want to hook both circuits up so that both lights are on. By connecting both black wires to ground and red to power on factory harness.
September 10th, 2017, 08:21 PM | #12 |
Ninja 250r Noob
So your saying to solder the Black wire and the Black/White wire into the Black/Yellow on the OEM connector? Then the Red in to the Green?
Is it safe to wire two wires into one?
September 10th, 2017, 08:50 PM | #13 |
September 11th, 2017, 12:52 PM | #14 | |
Those are cool easy to use connectors! AKA SAE power connectors. I bought a 5-pack to wire up all my bikes with trickle-charging. Cut each connector from junction and ran wire to battery. NOCO ISCC2 5-Way SAE Adapter Connector |
Wiring a DIODE for 4 L.E.D turn signals | AnarchoMoltov | 2008 - 2012 Ninja 250R Tech Talk | 126 | November 9th, 2021 12:13 PM |
Turn signal wiring for dummies? | mayornyc | 2008 - 2012 Ninja 250R Tech Talk | 2 | May 27th, 2017 07:36 AM |
Turn signal wiring issues | StuntPuppy | 2008 - 2012 Ninja 250R Tech Talk | 5 | February 25th, 2017 06:25 PM |
Turn signal wiring issues | StuntPuppy | 2008 - 2012 Ninja 250R Tech Talk | 1 | February 25th, 2017 01:10 PM |
Need wiring help for new turn signals | Insane Pie | 2008 - 2012 Ninja 250R Tech Talk | 15 | May 24th, 2014 02:26 PM |
