June 27th, 2009, 08:31 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): 1996 Ninja 250 Posts: 5
88-07 Bike part out $700 obo
Located in Plano tx
All parts are interchangeable for year models 88-07 on the ninja 250's... The bike is near completely dismantled due to being mostly just a parts bike... It was laid down so front fairing is cracked up pretty bad, Left handle bar broken off, forks bent, seat torn... and that's about all I can think of that is messed up. Also I have 2 engines for the bike. 1 has a cracked case or an completely obliterated head gasket, most likely cracked case though, and 1 has spun rod bearing which has 6k miles on it and I have gone through the engine contemplating taking on the job of replacing the bearing and internally looks alright... just some metal shavings from the bearing which it looks like the oil screen and filter caught most of them. But yeah, mostly everything else is in decent shape... I really just need to get it out of my damn garage. Frame is titled as well... |
July 30th, 2009, 12:54 PM | #2 |
Join Date: Apr 2009 Motorcycle(s): 07 ninja 250 Posts: 20
do you have the 4 main rear fender bolts? or any windscreen bolts? or a clutch lever
August 2nd, 2009, 06:58 PM | #3 |
Join Date: Jul 2009 Motorcycle(s): 06' Ninja 250 Posts: 6
Do you have the metal bracket that holds the headlight and gauge cluster? It's two pieces, a football-goal looking piece, and a triangle piece that bolt together.
August 9th, 2009, 02:45 PM | #4 |
Do you have the ignition box for 89 (the older style box uses less pins)
Posted via Mobile Device |
2005 Pre-Gen Ninja 250 Track/Race Bike - $1350 OBO | stimpee | Motorcycle-related | 0 | February 10th, 2015 07:39 PM |
2008 Ninja 250 Track/Race Bike - $2750 OBO | stimpee | Motorcycle-related | 0 | February 10th, 2015 07:37 PM |
[motorcycledaily.com] - MD first Ride: Kymco Myroad 700 (Bike Reports) (News) | Ninjette Newsbot | Motorcycling News | 0 | June 18th, 2013 08:40 PM |
Pre Gen Part bike part out | A7xschecter6661 | Motorcycle-related | 28 | July 5th, 2012 12:49 PM |
08' Ninja 250 Parts bike part out *you name the part and price* | BuckyNaked | Motorcycle-related | 106 | July 12th, 2011 02:01 PM |
