June 7th, 2010, 11:39 AM | #1 |
Preparing for a trip. Needing some advice.
Ok so I'm making some vacation plans to head up to the TN mountains near Gatlinburg, TN. In preparation I have rebuilt a trailer I purchased from Harbor Freight a couple years back. All new lighting, new decking, 2 new wheel stops, new D-rings for tie downs, and all new paint.
Question #1: Where is the safest place to tie down the 250's. I usually use some soft straps and tie down straps on or near the triple and handle bars and again on or near the passenger pegs. The suspension on the 250 is a little softer than I'm used to on my 1000RR and after adding the straps, it seems to pull the bike down more than I would like. Is there a better way? If not, will this damage the suspension? Question #2: Since I'm putting 2 bikes on a trailer that is only 4' wide, the front and rear tires need to be closer to the outside of the trailer to avoid hitting the bar ends from each bike together. This is not an issue until it comes time to tie them down. My concern is the outside straps have little to no angular pull. These straps are almost pulling straight down. I know the more angular pull, the better the stability. Is there a concern here? Question #3: The elevation here in Jax, Florida is pretty much Sea Level. The intent is ride the Blue Ridge Parkway with my wife on the 2 bikes. What effect can I expect going from sea level to over 6,000 feet in elevation? I know the jetting will be affected but will the bikes be ok?
June 7th, 2010, 12:07 PM | #2 |
Join Date: May 2009 Motorcycle(s): '98 EX250, '02 EX250, '08 250r, '03 SV650, '98 GSXR750 '03 Hayabusa, '87 YSR50, '84 ZX900, +MORE Posts: A lot.
This is how I trailer my bikes:
CraigHarris.org Pacific Track Time CraigsWeb See you at 2014 MotoGP Laguna Seca! We'll be camping on Fox Hill. AFM #278 |
June 7th, 2010, 12:36 PM | #3 | |
As for elevation, I don't know what mine would do at sea level, but at the parkway elevations (and we don't get close to 6000 feet to the best of my knowledge... at least not the VA part of it!) I was ok stock, but it was a bit lean for my liking, so I have 2 washers on the needles which keeps her much happier.
June 7th, 2010, 12:40 PM | #4 |
This thread should help - my bike is in # 16
http://www.ninjette.org/forums/showthread.php?t=13986&
new rider who needs advice on trip from today | juanpak87 | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 1st, 2013 05:36 AM |
Needing Some Tire Advice | Flashy | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 19th, 2012 07:40 PM |
May be needing an 08+ engine.... | LoneRonin | Items Wanted | 0 | June 23rd, 2011 10:35 AM |
Oil Leak, I think I found it but just needing some advice | jaustin77 | 1986 - 2007 Ninja 250R Tech Talk | 2 | May 11th, 2011 12:56 PM |
Needing blip on startup. | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 34 | March 28th, 2011 10:52 AM |
