Old June 30th, 2010, 06:12 AM   #1
lonewolf05
lonewolf05's Avatar
Motorcycle(s): 09 Ninja 250R
HB MGP Growler
Hey guys any information would be very helpful on this... I have added the MGP Growler slip-on to the bike. I was recently looking at Tyga's website and saw a set of race headers only $128. Would it be worth it to add this to get some more power?
lonewolf05 is offline   Reply With Quote
Old June 30th, 2010, 08:46 AM   #2
caliente103
caliente103's Avatar
Motorcycle(s): Red 08 250r
you should have gotten A P
Posted via Mobile Device
caliente103 is offline   Reply With Quote
Old June 30th, 2010, 09:00 AM   #3
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
lol
Adding a header will help with performance, but if you do that you will need to jet the bike. also you need to find out if the slip on you have now will fit onto the header. I belive a aftermarket header are a little bit bigger in size than oem piping. Your slip on is made to fit onto the oem pipe, but I may be wrong.
Last futzed with by scotty; June 30th, 2010 at 10:09 AM.
scotty is offline   Reply With Quote
Old June 30th, 2010, 09:05 AM   #4
scotty
scotty's Avatar
Edit: I just looked at the web site, I belive you have to buy these parts also to make it work. If so your up to $300
http://tyga-performance.com/site/pro...oducts_id=1781
Old June 30th, 2010, 10:05 AM   #5
ztrack157
The Sportisi Master
ztrack157's Avatar
Motorcycle(s): 2008 Ninja 250
you'll have to pay someone to cut up your growler and modify it to make it work.
Sportisimoto USA is born.
ztrack157 is offline   Reply With Quote
Old June 30th, 2010, 10:22 AM   #6
Kitdog
Kitdog's Avatar
Motorcycle(s): 2009 Ninja 250r, 1996 Yahmaha YZ 125... Both in Blue the coolest color
I would be willing to bet that it will only work with their muffler... A welder may be able to help fix it but it might be more work than its worth...
"Well you know, for me, the action IS the juice"
Kitdog is offline   Reply With Quote
Old June 30th, 2010, 10:27 AM   #7
lonewolf05
lonewolf05's Avatar
Hmmmm.... I don't mind jetting it. Maybe ill give tyga a call and ask them what else is needed
Old June 30th, 2010, 11:06 AM   #8
Kitdog
Kitdog's Avatar
I would say ask them what the outside diameter of the pipe is... then measure the inside diameter of your growler, this will tell you how it will fit, I just went and looked at mine and the elbow that attaches it to the stock headers goes up to a larger diameter to fit the growler... you might be able to re-engineer it to work.
Old June 30th, 2010, 11:19 AM   #9
lonewolf05
lonewolf05's Avatar
Alrighty will do, Sent them an email. Much appreciated!
Old March 19th, 2011, 01:31 PM   #10
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
Any outcome?
caps is offline   Reply With Quote
MGP Growler checho323 Motorcycle-related 4 January 29th, 2015 04:07 PM
MGP Growler up for sale NevadaWolf Motorcycle-related 15 January 7th, 2013 01:59 PM
MGP Growler James13 2008 - 2012 Ninja 250R Tech Talk 5 October 9th, 2012 10:16 AM
Another MGP Growler NathanUc Motorcycle-related 6 July 20th, 2011 03:18 AM
MGP Growler, yes or no? peachdiddy 2008 - 2012 Ninja 250R Tech Talk 10 August 31st, 2010 10:31 PM
