Old May 10th, 2014, 07:09 AM   #1
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Front Brake Lever Wont Activate Brake Light
I'm looking at wiring schematics, but was wondering if anyone had this issue? The rear brake will activate the brake light, but using the front brake, the light won't come on. Any help would be appreciated.
Thanks~
Old May 10th, 2014, 07:10 AM   #2
kennetht
kennetht's Avatar
did it work prior? or has it never worked before?
kennetht is offline   Reply With Quote
Old May 10th, 2014, 07:12 AM   #3
Thanks~
Both switches are in parallel connection with the brake light.
In your case, look for a defective switch or open circuit (loose connectors or broken wires) for the front portion.
Old May 10th, 2014, 08:09 AM   #4
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
I bought bike used, 8,000 miles. PO not available to answer. Just trying to fix up little things. He hacked this bike pretty good. I tore it down in November to jet carbs, remove air box, pod filters. Fuse for horn is removed, but when I replaced it, it works. He removed license plate light for a crap hack of the fender eliminator, and left wires dangling in rear compartment.
Is the front switch part of the lever assembly, or separate?
Old May 10th, 2014, 08:13 AM   #5
r6boater
Motorcycle(s): '04 R1 and '08 Ninja 250
Separate:
http://www.mrcycles.com/oemparts/a/k...aster-cylinder
Check out this Ninja 250 roadracing youth---> TheDraik77 <--- My son
r6boater is offline   Reply With Quote
Old May 10th, 2014, 08:18 AM   #6
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Awesome. Tearing bike apart now. Thanks all for help.
Old May 10th, 2014, 11:56 AM   #7
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Was able to get down to just the switch, and its bad. I can move the prongs on the switch and get good readings with my meter, but just moving the prong will make or break the switch. Going to get a replacement.
Also, I didn't check while I was there, but I should be able to get voltage on one of the wires coming in, correct?
Front brake wont activate tail light radi4fun 2008 - 2012 Ninja 250R Tech Talk 2 April 24th, 2013 06:37 AM
Rear Brake Doesn't activate Brake Light And DOT3/4 FRONT BRAKE OIL coelgrim 2008 - 2012 Ninja 250R Tech Talk 16 March 11th, 2013 05:10 PM
Rear brake wont activate brake light-HELP skilletmo 2008 - 2012 Ninja 250R Tech Talk 8 March 9th, 2013 11:09 AM
