Old September 25th, 2014, 12:58 PM   #1
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
carbs - how the frak do they work?
So not my Ninjette, she's running fine.
My wife's bike, however....
It's an '07 GS500F. It hasn't been ridden in over 3 years now, and I had pulled the carbs, removed and cleaned the jets, and put it back together (I hope correctly).
I can get it to start ok with the choke on. It won't idle though, without choke, and adjusting the idle doesn't seem to make a difference. Any ideas where I should start with the troubleshooting? There's a chance I didn't get all of the various interconnecting tubes in the right place, but I think I did. Should I borrow a carb sync tool and see if I can get that done first (although wouldn't it have to at least idle and stay running to do that)?
I'm open to suggestions. Thanks.
Worldtraveller is offline   Reply With Quote
Old September 25th, 2014, 01:02 PM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Googling "gs500 carburetor" yielded considerable video and troubleshooting content.
Old September 25th, 2014, 01:25 PM   #3
flitecontrol
Motorcycle(s): Rebel 250s, Ninja 250s VN750s (currently nine total)
When gas is left in a carb, it can obstruct the internal passages as well as the jets. Carb spray isn't a sufficiently aggressive cleaner to remove stubborn deposits. Sounds like your carbs are still dirty. Get a can of Berrymans Chem Dip (around $16 at the local Wal Mart) and soak only the metal parts for a minimum of 24-48 hours. Rinse well with water and blow out all the openings with high pressure compressed air. Or if you have access to a sonic cleaner, use that as it will clean it quickly.
The Chem Dip can be used several times before it becomes contaminated and needs to be replaced.
Draining the carb before extended storage will keep the carbs from gumming up.
flitecontrol is offline   Reply With Quote
Old September 26th, 2014, 09:55 PM   #4
Rifleman
Old and slow
Rifleman's Avatar
Motorcycle(s): Suzuki TL1000R, Honda CBR600F3, Ninja 250
Carbs = magic...
However, you can learn magic.
Yes as Flitecontrol said, gas, old gas... old gas that evaporates in a carb leaves lacquer or varnish... in very small passages and ports...
two things that work, soaking in carb cleaner and blowing it out with high pressure air. may take two or three times...
once you get them clean, they should work much better... having to keep the bike choked to keep it running at idle... = lacquer in the idle jets (the smallest)
Rifleman is offline   Reply With Quote
Old September 26th, 2014, 10:00 PM   #5
verboten1
verboten1's Avatar
MOTM - June '15
I bought an ultrasonic cleaner specifically for carb work. If a carb comes off a bike, it now comes apart and takes a nice 20 minute long heated bath and it's worked on everything I have put in there!
Ride more, worry less.
Old September 30th, 2014, 08:40 AM   #6
Worldtraveller
So not just the jets, huh? I've looked at a couple of the various S500 videos, but not all of them yet. I'd love to just trailer it over to a professional, but I'm trying to learn how to do this stuff on my own to save money, and support my racing habit.....
Old October 2nd, 2014, 01:29 PM   #7
HKr1
IC2(SW)
HKr1's Avatar
Old October 2nd, 2014, 01:30 PM   #8
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Replace the pilot jets.
Worlds fastest 250 ninja
Old October 2nd, 2014, 03:15 PM   #9
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
At the most basic level, carbs work using the Bournulli principle: http://en.wikipedia.org/wiki/Bernoulli%27s_principle
Essentially, the pressure of air in any given spot is related to its velocity. Carbs have a section with reduced area such as a venturi, and in that spot the air speed has to increase. It increases because the same amount of air is going through a smaller area. Because the speed increases the pressure decreases, and that draws fuel out of the float bowl through metered orifices called jets.
But really, you still have solidified crap inside the orifices, passages, and jets in the carb. Carb spray or brake cleaner (my preferred fluid) should spray through all openings and passages. Removing all the jets, pilot tubes, needles, etc, is generally required when cleaning carbs that sat for a very long time. Also, remove the rubber bits like the diaphragms, O-rings, and gaskets before cleaning as most cleaning fluids will damage these "soft" parts.
Old October 3rd, 2014, 07:20 AM   #10
Rifleman
Old and slow
Rifleman's Avatar
wow, that is a beautiful diagram of a CV carb.
you see the "pilot jet" (item #1) that is going to be your "it won't idle" problem area... that path, through the jet, to the up stream or down stream side of the butterfly, as well as the "idle mix screw"...
all those path ways are VERY small, literally the size of a sewing needle. Maybe even smaller... very prone to varnish clogging... they have no moving parts and only the smallest delta P when operating so nothing to really clean them during normal ops...
the main jet will always be in the "middle" right under the main venturi... the pilot will be another brass screw in type jet... but it will be off center somewhere under the float.
that's where you want to spray the carb cleaner, and blow it out with compressed air until you can feel air blowing around the butterfly... back the idle mix screw out all the way and clean... you can try and shut it (count the turns going in) and then put the same amount of turns coming back out when you assemble after cleaning... 2.5 turns is a common number... although some are 4 turns open...
be sure to clean your choke ports as well... the worst thing for a carb is to sit full of gas, and then dry out...
everything gets clogged and coated.
08 carbs on 07 sigma44 1986 - 2007 Ninja 250R Tech Talk 10 January 26th, 2015 10:05 AM
Need 08+ Carbs Donnyd21 Items Wanted 2 September 19th, 2014 04:38 PM
[motorcycle.com] - AMA Says To Ride To Work On Ride To Work Day Ninjette Newsbot Motorcycling News 0 June 9th, 2014 11:50 AM
DIY- Carb Work on 2008 Ninja 250 carbs kkim 2008 - 2012 Ninja 250R Tech Talk 40 September 8th, 2011 07:51 AM
Shim Carbs - Would These Work? nattygirl 2008 - 2012 Ninja 250R Tech Talk 13 February 16th, 2011 12:30 PM
