Old June 27th, 2016, 05:02 AM   #1
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Helmet foam liner adhesive
Good morning,
While I was removing my helmet's interior, I notice a part of my helmet foam liner "unglued" partly from the helmet shell.
If I want to glue it back, I think I should stay away from any solvant based adhesive.
Any of you already attempt this kind of repair? If so, what product did you used?
Thanks for your help.
broken neck is offline   Reply With Quote
Old June 27th, 2016, 05:20 AM   #2
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
What's the build date on the helmet?
I ask because that's the kind of thing that happens to really old helmets... if the helmet is more than 7 years old (or 5 years from date of first use), time to replace it.
This isn't just hype to get people to buy helmets. I once found an old helmet of mine in the attic. The EPS foam liner was hard as a rock and the glue had gotten brittle. I'd purchased that helmet about 10 years prior and it was on sale, so probably had been made a couple of years before I bought it.
To answer your question: Epoxy should work. Here in the US we also have something called "Gorilla Glue" which may be available north of the border. This is great stuff and should work also, but be aware that it foams and expands as it sets. You'll need to clamp, and use small amounts.
You can also use 3M Super 77 spray adhesive. This is what model builders use.
EPS stands for Expanded Polystyrene, which is the same as styrofoam. In other words, the stuff foam coffee cups are made of. Get one and test your glue on it. If the foam doesn't dissolve, it'll work.
Old June 27th, 2016, 07:03 AM   #3
broken neck
adouglas, the production date of my helmet is May 2012 and I've been using it for 3 years.
I've looked and we do have the Gorilla product, so you were talking about gorilla epoxy glue then?
Good idea for the coffee cup, I haven't thought about it.
Thanks.
Old June 27th, 2016, 08:22 AM   #4
adouglas
adouglas's Avatar
No, the brown, water-activated stuff. Spray water onto the surfaces to be glued, apply a small amount of glue & spread out, clamp. Trim off whatever squeezes out with a razor blade.
Might want to do a test on some scrap materials to see how it expands.
Helmet line adhesive wearing off, halp! Aggrotech Motorcycle Gear 3 June 15th, 2016 12:13 PM
Washing Motorcycle Helmet Liner az3200 Gear-related 13 July 11th, 2013 04:09 AM
Adhesive for turn signals Maelstrom 2008 - 2012 Ninja 250R Tech Talk 9 July 27th, 2012 07:59 AM
how to remove adhesive from ninja decal? str8t six General Motorcycling Discussion 13 October 22nd, 2011 08:41 AM
Need adhesive/glue for tank pad davidgz General Motorcycling Discussion 3 September 7th, 2010 05:55 PM
