August 6th, 2016, 01:27 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): '11 ninja 250, '09 Sprint ST 1050, '06 KTM ADV 950, '00 ttr125, '98 xr400, '95 xr250 '83 CR 480R, '76 TT 500 Posts: 2
air box mod
Has anyone ever drilled say 2" holes in the air box? i was thinking doing it in the flat area just in front of the battery box along side the snorkel. Any performance increase?
August 6th, 2016, 01:37 PM | #2 |
Figure 17, page 17.
http://www.leovince.com/files/F1604/9213%20-%20GB.pdf |
August 6th, 2016, 10:15 PM | #3 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I always wondered about this. Didn't know it was already being done.
I didn't like the idea of running pods, and removing the snorkel seemed so/so
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
August 7th, 2016, 08:22 AM | #4 | |
Vintage Screwball
MOTM - Mar '16
Doing that to a standard carbed Ninja will make it a pain to tune.........like pods. Removing the snorkel and adding an exhaust will get you 30-31 HP. I would like to see a dyno sheet with pods if someone has one to compare peak HP and HP curves.
Goin' fast on slow bikes! |
August 7th, 2016, 08:38 AM | #5 |
Certifiable nontundrum
MOTM - Sep '13, Sep '16
Folks have done it, there are threads around iirc
Oh wow, there I even one listed below on my screen
Last futzed with by JohnnyBravo; August 7th, 2016 at 08:39 AM. Reason: Saw modded airbox in the related post window |
August 7th, 2016, 10:41 AM | #6 | |
Nope. Pods aren't hard to tune if you have some patience, just use your noggin a little bit. Also: no, opening the airbox doesn't make jetting difficult at all. Cutting open the airbox is the best of both worlds in my experience. I cut the whole lid open on my pregen at one point. Improved throttle response, good top end power, good start up, good idle, good sound; all with the factory air filter and factory location to protect from water intrusion. It did need some minor tweaks to the jetting to get there though. Search a little. Area P has done numerous posts (and an entire thread ) about the gains associated with full systems, pod filters, modified airboxes, with and without snorkel, etc etc etc including dyno sheets. They've even hosted some Q&A with members who need more convincing. I'm not claiming to be an expert, but it's jetting; it's not rocket science. There's plenty of online documentation on how to tune CV carbs if you're willing to take the time to read and then go do science. |
August 7th, 2016, 10:50 AM | #7 | |
https://www.ninjette.org/forums/show...&postcount=144 EDIT: here you go, there's a dyno chart on this page for the full exhaust, pod filter, and fuel tuner. http://areapnolimits.com/products/Sl...a-300-2013.php |
August 7th, 2016, 03:36 PM | #8 |
thank you for the quick info kids! that link is exactly what i was thinking. :dance cool:
A little back ground on where i am coming from. I have two 2011 250s. One i race at omrra events in the ninja cup series as well as other events and kart tracks. We are very limited on what we can do will these bikes and mine is make about 31hp. The other is currently stock (performance wise) and is my daily year around commuter,supersport touring machine and camping special! lol I have over 30k miles on it now and have a full leo gp exhaust system and factory pro stage 1 jet kit that has been siting around for some time now. i was thinking about slapping them on sometime maybe soon and was thinking what i could do to the air box and carbs as ill be there jetting them. as time goes on and more things need a refresher those things will be upgraded. Maybe a bigger bore down the road. |
N4's Battery Box Mod | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 5 | April 19th, 2013 06:27 PM |
K&N air filter to stock air box | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 29 | July 28th, 2012 06:33 AM |
Air Box Mod and Rain Riding | tito517 | 2008 - 2012 Ninja 250R Tech Talk | 7 | April 19th, 2011 10:32 AM |
