November 9th, 2013, 09:45 PM | #1 |
Shimming vs Snorkel out
Hi all,
I know that a lot info about shimming and remove snorkel. Short story, I have ninja all stock except dbs silencer. Recently I replace my FP needles with stock needles cause with FP accelertion was good but on RPM needles always higher then KM needles (not with the stock needles). I don't know something wrong with the jetting or what. So now I am running stock needles running good, then try to put 2 wahser each needles even better, but with 2 washer each, it is hard to hit 9K. So what i know if i put wahser a lot of people is remove snorkel.My question is which one is the good result between remove snorkel or change drop in filter to compesate my jetting? |
December 4th, 2013, 08:38 PM | #2 |
bump
December 7th, 2013, 02:00 AM | #3 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
I've found the snorkel-removal increases engine sound (if that's a factor for you) by about 10db. Because I travel from 5200 to 9800 feet altitude pretty regularly, it was a good compromise. I run a bit lean at 5200 but at 9800 it sits just right, and I get crisper acceleration and my top-end went up about 5mph.
There's an argument that un-shimming is harder to do than re-snorkeling, so I'd probably try the snorkel-removal first as it takes about 10 minutes max. Shimming might take 30 if you're knowledgeable with the process. |
December 7th, 2013, 12:50 PM | #4 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
I had the same problem when I shimmed. Awesome grunt down low but no power over 8ishK. Did you find out how to fix it???? I'm at sea level basically
December 7th, 2013, 07:30 PM | #5 | |
Depending on your mods, you may need to increase the main jet size. Something else is going on if you lost power over 8000 when you shimmed the needles. |
Modifying the snorkel | Hoodie Ninja | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 1st, 2012 08:42 PM |
removed the snorkel | azn77 | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 27th, 2012 05:01 PM |
Snorkel Gasket | indr | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 27th, 2012 05:44 AM |
inconsistent throttle/rpm after shimming and snorkel removal | Hokie11 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 23rd, 2009 03:17 PM |
Snorkel Pulling? | Daeldren | General Motorcycling Discussion | 8 | June 11th, 2009 06:53 AM |
