March 4th, 2013, 04:03 AM | #1 |
Join Date: Sep 2012 Motorcycle(s): ex500 ex250 Posts: 56
FS EX500 Rear shock
Pregen 250 owners, i have a ex500 rear shock that has 6,000 miles on it.
It does what it's suppose to, i have no use for it as i've upgraded to a fully adjustable shock but it cost me enough. Anyway this is a direct bolt on upgrade for the pregen 250's as the 88-07 ex250 were underspung and has no preload adjustment (86-87 did but then they changed it) Anyways ex500 rear shock $25+ shipping (usually around $17-$20 conus) Last futzed with by Oxide; March 4th, 2013 at 08:38 PM. |
March 4th, 2013, 07:25 PM | #2 |
Join Date: Mar 2012 Motorcycle(s): 2017 Motus MSTR (Kara), 1990 Ninja 600R (ZX600C3) (Scrappy) Posts: 185
DIBS!
PM Sent. |
March 4th, 2013, 08:39 PM | #3 |
Solddd
Last futzed with by Oxide; March 12th, 2013 at 10:18 PM. |
March 12th, 2013, 09:52 PM | #4 |
Does it raise the rear at all (not simply sagging less)?
March 12th, 2013, 10:18 PM | #5 |
no, the sv650 shock does though. by 1 7/8"
but you have to bore out the mounting holes from 10mm to 12mm And spread the lower mounting legs by like 1-2mm people say stuff about washers n this and that. i never used washers tho and mine worked perfect. |
Advice on newgen rear shock/ ex500 fork springs | choneofakind | 1986 - 2007 Ninja 250R Tech Talk | 18 | March 20th, 2011 07:02 AM |
For sale: 2003 ninja 250 rear brake pedal and rear shock | ReDnEcK | Motorcycle-related | 0 | October 6th, 2010 12:02 PM |
Replacing my rear shock with a newgen rear shock... | ReDnEcK | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 12:38 PM |
91 ex500 rear sprocket on 250r? | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 0 | June 19th, 2009 09:52 PM |
