Old September 11th, 2010, 05:53 PM   #1
ReDnEcK
ReDnEcK's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250R
fork springs - pregen vs newgen
Just wondering... can you use 08+ fork springs on a pregen bike? Are they stiffer than the pregen springs? Any ideas if its better or worse than just buying aftermarket springs?
Posted via Mobile Device
ReDnEcK is offline   Reply With Quote
Old September 11th, 2010, 07:55 PM   #2
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
I'm not sure if you can use them or not. I don't see why you couldn't, you can use the 500 springs in the pregen. And yes the newgen springs are stiffer then pregen, not by a lot, but they are stiffer.
sombo is offline   Reply With Quote
Old September 11th, 2010, 09:09 PM   #3
ReDnEcK
ReDnEcK's Avatar
Do you know if the 500 springs are stiffer than the 08 250 springs? That was the other option I had looked into...
Old September 11th, 2010, 10:39 PM   #4
sombo
sombo's Avatar
That much I do know and the answer is yes. They are indeed heavier then the newgen 250 springs.
250.org info on stiffening the forks.
500ex spring option info.
Old September 12th, 2010, 02:09 AM   #5
I'm not 100% sure. The pre-gens do have a .44 kg/mm spring rate in front, there are numerous sources that state this. In all reviews when the 2008 came out, kawi's press releases said "37 mm front forks (up from 36 mm), with revised spring rates". So whatever they are, they are stiffer than .44. But I can't find a spec for the new ones, and I have seen people quoting .44 for the new-gen as well; yet that doesn't seem right either.
Old September 12th, 2010, 02:39 PM   #6
iceman.kcmo
Motorcycle(s): 94 Ex250
you could try cutting the springs and making a "preload" spacer to take up the amount you cut off the spring. That is what i am going to toy around with on my spare set of springs.
iceman.kcmo is offline   Reply With Quote
FS: Pregen : Fork Springs, Fork Clamp, Factory Pro Jet kit FvnnyL3tt3r1ng Motorcycle-related 20 February 24th, 2016 08:24 AM
Can fork springs be changed without removing the fork tubes? AlanDog 1986 - 2007 Ninja 250R Tech Talk 26 April 23rd, 2014 05:19 AM
pregen engine in newgen? alex.s 2008 - 2012 Ninja 250R Tech Talk 6 October 19th, 2012 11:09 PM
Pregen vs. Newgen ambudriver General Motorcycling Discussion 7 May 7th, 2011 07:36 PM
Advice on newgen rear shock/ ex500 fork springs choneofakind 1986 - 2007 Ninja 250R Tech Talk 18 March 20th, 2011 07:02 AM
