Old March 5th, 2012, 10:56 PM   #1
atomicrm
Motorcycle(s): 2009 250R
1st to 2nd clutch slippage
if i am really getting on the bike and go from 1st to second i get what feels like at least like a lot of clutch slippage. my body shoots forward a lot as i slow down some from the lack of acceleration for that half a second or so. is this just typical wet clutch performance or is my clutch adjusted improperly?
i know I can shift clutchlessly. just curious if this is how it should react.
atomicrm is offline   Reply With Quote
Old March 5th, 2012, 11:04 PM   #2
atomicrm
the slipping seems to happen when i release the clutch to engage second when at high rpms. when i say high i mean like after nearly redlining
Old March 5th, 2012, 11:18 PM   #3
atomicrm
accelerate in first to redline, let off gas and clutch and shift very fast(motogp style ) let clutch back out and it seems like the clutch slips and struggles to engage at the high rpms once engaged it is fine though
Old March 6th, 2012, 12:54 AM   #4
Hard to tell from your description whether you're slipping the clutch too much unnecessarily, or if there is something wrong with the clutch adjustment.
Old March 6th, 2012, 07:25 AM   #5
No need to reach those high rpm's between 1 and 2.
Check that you have at least a minimum slack in the lever entering the clutch cover when the clutch is released.
Old March 6th, 2012, 08:05 AM   #6
Nemesis
CVMA #74 WSMC #750
Nemesis's Avatar
Motorcycle(s): All of them
Normal and operator error. Move along plz.
Old March 6th, 2012, 08:25 AM   #7
cbdallas
cbdallas's Avatar
Motorcycle(s): 2007 Ninja 650R
My '94 did this too until I replaced the plates, fibers & springs. I found out after I took it apart that I probably could've gotten away with just new springs, as the plates & fibers looked fine.
But before you go tearing into the bike, make sure that when you release the clutch, there's at least a couple mm of space between the lever and the base..that's your freeplay, and there needs to be some. If the handle rests against the base after release, use the adjustment screw on the base to add some freeplay.
If you get slippage after an adjustment, you may need new springs, or a whole new setup depending on how worn the fibers & plates are.
cbdallas is offline   Reply With Quote
Old March 6th, 2012, 01:55 PM   #8
Whiskey
Sounds like you're revving it too high in 1st & it's you not the bike tbh.
the shift from 1st to 2nd is the longest, so it sounds like you're botching the shift by pinning it to redline and mis-judging where your revs need to be to re-engage smoothly.
Try revving it to about 8k then changing see if that helps.
I wouldn't clutchless shift 1>2, that's tempting fate with hitting neutral, but 2>3 and so on are fine.
The bike can get a little picky about shifting if it needs an oil change.
Adjust your riding style (lower RPM shift from 1st) , check your lever for play (is it in spec?) and change the oil & filter (In that order with a test run in between each step) before deciding you have to take the bike apart & buy loads of new pieces.
2nd trip to TWS didn't go as well as the 1st sharky nrk Ninjettes At Speed 23 September 11th, 2014 06:43 AM
Choppy throttle in 1st and 2nd gear ally99 2013 - 2017 Ninja 300 Tech Talk 13 February 10th, 2014 06:15 PM
Occasionally shifts to neutral from 1st to 2nd woofer987 2008 - 2012 Ninja 250R Tech Talk 8 May 6th, 2013 08:52 AM
Going from 1st to 2nd I hit neutral?? TwoWheelNinja General Motorcycling Discussion 6 October 10th, 2012 07:49 PM
Ninja 250, 1st (2nd?) Impression Jiggles General Motorcycling Discussion 28 July 24th, 2012 09:32 PM
