April 21st, 2014, 11:45 AM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Sprocket sits in Cush drive, but there's wiggle room.
I removed my rear wheel to check my bearings because my wheel didn't feel smooth and clicked while rotating on a stand. I've re assembled the wheel and when you rotate it, there is wiggle room in the Cush drive so the sprocket moves after the wheel is rotated a bit. I can't remember if this is normal or not. Is it?
April 21st, 2014, 11:52 AM | #2 |
Normal. It moves around a bit forward and back. Some people shim the cush drive by placing thin plastic or other material in the gaps so it doesn't move as much. Others just don't worry about it.
April 21st, 2014, 11:59 AM | #3 |
Join Date: Jan 2013 Motorcycle(s): 03' Ninja 250ex Posts: 333
Common problem. My bike had the same issue @ 3k miles.
What you can do is get a plastic milk jugg or similar plastic and cut small pieces to shim between the Cush and where it makes contact with the Hub. I packed mine a bit tight but it's preference. You will feel a noticable difference when you take off from a start.
Perform Random Acts of Coolness!!ATGATT |
April 21st, 2014, 12:04 PM | #4 |
Motorcycle Nurse?
Alright thanks guys, I was trying to figure out my clicking issue and it seems to be the chain. I can't figure out why it's clicking though.
April 21st, 2014, 12:59 PM | #5 |
How old is the chain? How many miles?
April 21st, 2014, 07:10 PM | #6 |
Motorcycle Nurse?
April 21st, 2014, 07:50 PM | #7 |
Did you change the sprockets out when you replaced the chain?
April 21st, 2014, 09:26 PM | #8 |
Motorcycle Nurse?
April 21st, 2014, 09:51 PM | #9 |
I thought about making poly-u Cush drives but people have mention that it's too stiff and doesn't have enough give to prevent damage to the countershaft bearings and chain when slamming gears. The looseness is normal and feathering the clutch will alleviate the slight pause before the sprocket hub engages the Cush drive.
April 21st, 2014, 10:24 PM | #10 |
normal.
April 22nd, 2014, 04:40 AM | #11 |
Board Member
Normal. Buy new cushions or shim if bothered.
Cush Drive Questions | tbeck3r | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 18th, 2015 09:45 PM |
Drive Lash and the Cush drive | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 20 | November 19th, 2014 01:55 PM |
Cush Drive Shim | PsHYk | 2008 - 2012 Ninja 250R Tech Talk | 24 | June 30th, 2012 12:51 PM |
WTB: 08+ Sprocket Carrier and Cush Drive | SNAPPY | Items Wanted | 0 | April 4th, 2012 08:37 PM |
Cush Drive Replacement | jorgecornet | Videos | 11 | May 26th, 2010 08:27 AM |
