Old January 28th, 2014, 07:29 AM   #1
agentbad
agentbad's Avatar
What headlight bulb are you using?
The stock headlight bulb seems far to weak for night riding. What's a good bulb to improve visibility at night? H4, LED, HID, Night vision goggles?
Old January 28th, 2014, 07:54 AM   #2
DaBlue1
DaBlue1's Avatar
I have the Phillips MotoVision Motorcycle Bulb H7 bulbs. Its an excellent stock replacement. You need an H4 bulb. Quite a few members on other forums use them. They also have great reviews in the motorcycle community.
The light beam is white, goes out further and is about 40% brighter than stock. There is a very slight orange glow in the reflector, but you have to be on the right angle to see. It also shows on the ground at the trailing edge of the light beam closer to the bike.
Here is what the Phillips Motovision looks like on high beam during the day shining into a camera lens.
You may be able to find other inexpensive H4 headlight bulbs that are brighter compared to stock but maybe more expensive or lower quality.
Philips is known for making very good lighting products. Some others are listed below.
PHILIPS MotoVision Light Bulb
PHILIPS Xtreme Power H4
Philips Blue Vision
Bikemaster Vision X H4 Bulb
GE Nighthawk H4-55NH/BP
Sylvania SilverStar Headlight Bulb
Old January 28th, 2014, 02:39 PM   #3
agentbad
agentbad's Avatar
Okay +1 for motovision.
Old January 28th, 2014, 02:50 PM   #4
I used a Sylvania Silverstar for the longest time. Really liked it as far as a stock voltage Halogen went.
Then I did a full bixenon retrofit with a D2S projector and 35W 4300k HID setup. I like that even better because it looks awesome and gives nice even lighting.
Old January 28th, 2014, 02:53 PM   #5
agentbad
agentbad's Avatar
Very cool did that all fit inside the stock light housing?
Old January 28th, 2014, 02:58 PM   #6
Yepp, barely. But it's in there. You have to get creative with the wiring.
Old January 28th, 2014, 03:22 PM   #7
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
If you want, I'll sell you a set of Sylvania SilverStar H4 bulbs at a nice discount. I had bought them instead of H7 bulbs and only realized it after I had cut off the UPC. Other than missing the UPC, the packaging is still intact.
Old January 28th, 2014, 03:24 PM   #8
agentbad
agentbad's Avatar
Talking
Hell yeah thanks.
Old February 11th, 2014, 10:16 PM   #9
n4mwd
n4mwd's Avatar
If the H4 stock bulb isn't bright enough, go with HID or LED. The high intensity halogen superbright bulbs draw too much current and can also overheat things. Not to mention that they burn out really quick.
My Ninja Blog
Old February 12th, 2014, 12:07 AM   #10
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
H4 Hyper White I think..maybe 6K. Cheapy off of Ebay for $6. First one lasted 8k miles and I use Hi 100% of the time.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old February 12th, 2014, 05:26 PM   #11
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Couldn't find it on their website but cycle gear was/is selling LED headlight for $30. I believe it fits right into a bucket but it's up to the user to install it. It would fit just fine in the stock assembly.
Mods: Offset clutch pressure plate
Old February 15th, 2014, 02:05 AM   #12
RBN
RBN's Avatar
Motorcycle(s): Frankenstein
Not wanting to jack your thread, but I've been wondering about these el'cheapo HID systems:
http://www.ebay.co.uk/itm/291019662888
That's two 'bikesworth' of lighting for £23 I've heard varying reports about them, I figure if one bulb/ballast lasts a year then i'd be happy. And doesn't require any actual "wiring" just plug and play.
Anyone actually tried them?
RBN is offline   Reply With Quote
Old February 15th, 2014, 09:58 AM   #13
El Cheapo HIDkit = no bueno
Old May 21st, 2014, 08:37 PM   #14
cmbeebe
I have been looking at two different types here. One is the h7 here http://www.cyclegear.com/CycleGear/P.../p/34909_41208
The other one is the motovision you guys have been talking about.
http://www.cyclegear.com/CycleGear/P.../p/34200_41212
Is it worth the extra 14$ (two bulbs) for the motovision??
cmbeebe is offline   Reply With Quote
Old May 22nd, 2014, 04:36 AM   #15
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Sylvania SilverStar is what I use on mine...I believe DaBlue was one of the people who asked me what bulb I used during a group ride in Asheville.
Even the guy w the HID (mommaru) mentioned how bright my light looked.
I personally loved that light and went right out and bought 2 more for my new 300
I would suggest going w a brite white model and not anything w/ a blue film...although thats just personal opinion.
Old May 22nd, 2014, 08:13 PM   #16
cmbeebe
How long have they lasted for you? I keep seeing that they do not last to long?
Old May 22nd, 2014, 08:44 PM   #17
EsrTek
EsrTek's Avatar
I had my bike 2yrs, 12k+ miles and they still worked when I sold bike.
headlight bulb james250ninja 1986 - 2007 Ninja 250R Tech Talk 1 September 4th, 2014 05:36 AM
Headlight bulb replace Bill N 2008 - 2012 Ninja 250R Tech Talk 13 June 26th, 2014 08:07 PM
headlight bulb recommendation eddiekay General Motorcycling Discussion 13 July 2nd, 2013 09:26 PM
New headlight bulb??? set608 1986 - 2007 Ninja 250R Tech Talk 2 May 8th, 2013 10:09 AM
Headlight bulb keeps blowing caps 2008 - 2012 Ninja 250R Tech Talk 11 August 31st, 2011 06:17 AM
