Old April 21st, 2014, 10:52 PM   #1
Jammerkiller
lurking about........
Jammerkiller's Avatar
Motorcycle(s): 2004/2005 Ninja EX250, VFR750, Shadow ACE750, NC700X
Rear shock option for pre-gen.
I've seen a lot of posting about rear shock mods on both old and new Ninjas. I have been researching this for a few months and finally made a decision...
Originally I got an SV650S rear shock, for it's adjust-ability, and because it was free! But, after checking out forums where people have installed it, they say it's really too stiff for the pre-gen unless you're a heavy rider. (250+ lbs) So, I went with a new-gen 250 shock. According to the web, this is a direct bolt-in replacement. And, it sure was. Plus, you can adjust it's height and it's a little stiffer than the OEM pre-gen shock. Overall the install was easy. It's best to use a rear stand to hold the swing-arm and the rear of the bike. Then I used a floor jack with a piece of 2x4 under the frame and just behind the engine to stabilize the bike while you remove the upper and lower bolts for the shock. (You may have to pump up the jack a tad for the new shock.) remove the old shock, install the new shock. (I used the original pre-gen bolts) Torque to 33ft-lbs and you're done! The SV shock would have required some grinding and some drilling on the new shock mounts. Not a difficult task, but too much work to install a shock that may be too stiff to begin with.
eBay.....$60
New-gen on the bottom. Note the adjustment ring. The upper knuckle and bolt hole line right up. Same for the bottom.
Once I ride the bike later this week, I'll give more info on how it feels. Suspension feels better just by sitting on it.
Fast....Cheap.....Reliable...... You can only pick two.
Jammerkiller is offline   Reply With Quote
Old April 21st, 2014, 11:45 PM   #2
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
I was gonna go that route but went with the 90's ZX-6C AIR SHOCK instead.
Perform Random Acts of Coolness!!ATGATT
kirk595x is offline   Reply With Quote
Old April 22nd, 2014, 12:24 AM   #3
Snake
Snake's Avatar
Do you have any pics? Sounds interesting. Was there any modifications required?
Old April 22nd, 2014, 12:53 AM   #4
ds650rida
Motorcycle(s): 636 250r
No mods required. Direct swap
ds650rida is offline   Reply With Quote
Old April 22nd, 2014, 02:11 AM   #5
Ninjinsky
Ninjinsky's Avatar
I fitted a GPZ 500 shock to my '91. Again a direct bolt in. Firmer and adjustable. I was very happy with the result.
Old April 22nd, 2014, 05:05 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
FYI, that's the spring preload adjustment. It does have some effect on ride height, but its purpose is to provide the proper tension on the spring for optimum suspension performance. The slight change in the unloaded ride height is merely a side effect (and meaningless once you get on the bike if you weigh more than the amount of preload).
I currently have a NewGen shock on my 500, which replaced a modded SV shock. The spring rate is just about perfect for my weight (the newer SV shock with the white spring has about the same rate as the PreGen). It's almost 75% stiffer than the stock 500 spring, so obviously that made a huge difference for me.
Last futzed with by InvisiBill; April 22nd, 2014 at 11:09 AM. Reason: Forgot some words...
Old April 22nd, 2014, 09:35 AM   #7
kirk595x
kirk595x's Avatar
Originally Posted by Snake View Post
Do[/url] you have any pics? Sounds interesting. Was there any modifications required?
http://s103.photobucket.com/user/n4t...vi8uw.jpg.html
You will need four 1/2 inch washers and thats all.
Old April 22nd, 2014, 06:42 PM   #8
Snake
Snake's Avatar
Cool, thanks.
Old April 22nd, 2014, 07:02 PM   #9
kirk595x
kirk595x's Avatar
No prob. If you decide to get one be sure change the shock oil. 10-15w would be fine and will only set you back $10-$15.
The only downside is the weight of the shock. It's at least double of the stocker but well worth the adjustability IMO.
Old April 23rd, 2014, 04:43 PM   #10
Jammerkiller
True that. It's not really for height adjustment, but does increase it a little. Good to know...
The SV shock I have has a yellow spring. (2001) I heard it's pretty hard unless you're a heavy rider.
Old April 24th, 2014, 04:46 AM   #11
InvisiBill
InvisiBill's Avatar
Yeah, that shock is quite different from the newer one with the white spring. If I remember correctly it's longer but has a shorter stroke. The spring is quite a bit heavier too - the white one is 430# (similar to the stock PreGen spring) while the yellow one is like 500 or 550 (around the NewGen spring's rate).
Old April 24th, 2014, 08:51 PM   #12
Jammerkiller
BTW, I rode her last night to a bike night. Rides much smoother than the stock shock, and it's preload is at minimum. I may notch it up a bit.
new gen rear shock subxero Items Wanted 16 April 16th, 2015 02:56 PM
New-gen shock on pre-gen baxtc1 1986 - 2007 Ninja 250R Tech Talk 28 October 30th, 2014 05:10 AM
new gen shock on pre gen juanpak87 1986 - 2007 Ninja 250R Tech Talk 14 September 9th, 2013 07:55 AM
WTB Suspension after market rear shock/exhaust Pre-Gen Ninja 250ex WesleySnipes Items Wanted 17 March 5th, 2013 08:27 AM
WTB - pre-gen shock Tony B Items Wanted 4 October 10th, 2012 01:58 PM
