Old August 16th, 2009, 11:49 PM   #1
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Clutch cable adjustment
How often do you adjust the clutch free play?
I have now adjusted mine twice in the 5500Km that I have done since new.
Is this cable stretch or a combination of cable and the clutch plates bedding in?
If it’s the plates bedding in how long does it take?
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old August 16th, 2009, 11:58 PM   #2
I don't think there is a set time or pattern to this. Yes, the cable will stretch a bit more initially and the plates wear as they bed in, but continued use of the clutch (and everyone uses it at a different rate depending on riding usage)will continue to wear the cable and plates.
Just keep it properly adjusted and lubed. Also, be sure to change your oil at least as often as recommended by the manufacturer... more if you want to be proactive.
Old August 17th, 2009, 12:39 AM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
Make sure you don't adjust it too tight as well One guy in another forum had his clutch adjusted way too tight and slowly burnt up his discs as they were constantly slipping. As annoying as it is having the handle with a little slack in it, it beats burning up your clutch plates prematurely.
VeX is offline   Reply With Quote
Clutch Adjustment JBinSD 2013 - 2017 Ninja 300 Tech Talk 12 February 11th, 2017 09:42 PM
Cable adjustment perch hole stripping indr 2008 - 2012 Ninja 250R Tech Talk 3 August 1st, 2013 05:25 PM
How long before your first chain tension adjustment.. and routine cable lubrication reaubideux 2008 - 2012 Ninja 250R Tech Talk 1 August 12th, 2011 09:54 PM
Fine throttle cable adjustment assembly broken. setasai 2008 - 2012 Ninja 250R Tech Talk 2 June 18th, 2011 09:10 PM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
