Old August 20th, 2009, 05:53 PM   #1
Hokie11
Motorcycle(s): Black 2009 Kawasaki Ninja 250R
a tad bit too much oil?
Just did my own first oil change at 700 miles. Followed the DIY and filled it up part way after I changed out the filter and drained all the old oil, started it up, let it sit a few min, then saw it was only about half way filled, so I added a bit more. I have a big 4L container of oil, and I used close to 2L without realizing it. When the bike is level and cooled, the oil is just above the F line. I still see air in the viewing glass, but I am a little concerned it is too high.
Should I leave it or siphon some out?
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front
Hokie11 is offline   Reply With Quote
Old August 20th, 2009, 05:58 PM   #2
Snake
Snake's Avatar
As long as you can see a bubble of air then you are fine and I would just leave it as is.
Old August 20th, 2009, 06:03 PM   #3
I agree.
Old August 20th, 2009, 06:05 PM   #4
Hokie11
*whew* good to know thanks!
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
[superbikeplanet.com] - From the Hip: A Little Bit Country, A Little Bit Rock & Roll Ninjette Newsbot Motorcycling News 0 October 1st, 2012 11:20 AM
5qt. G-Oil Synthetic Motor Oil (5w-30) Free After $26 Rebate setasai Miscellaneous 3 May 25th, 2011 01:59 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
