Old November 13th, 2009, 09:30 AM   #1
fixture
Motorcycle(s): 2003 Ninja 250
best way to seat the air box to carbs.
I took my carbs out to clean them and the bike has not been running good. I set the mixture screws to 2.5 out and set the idle after warmed up. once i rev the engine it hangs and wont come down. I lubed the cables and it snaps back fine. I noticed that the airbox and the little round rubber/spring seals that are seated close to the carb intake side, are not fully sealed to the intake side of the carbs. I tried to slide the airbox closer, but it just wont go any further closer to the carbs. Any ideas?
I was thinking of drilling new holes below the battery so that I can push the airbox further forward, then tighten the screws below the battery. I believe this is my issue of hanging idle.
Jonathan
aka fixture
fixture is offline   Reply With Quote
Old November 13th, 2009, 10:12 AM   #2
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Jonathan - take a look at Kelly's post on this issue.
You need to fix that. You are sucking in unfltered air through that opening as well as leaning out your mixture by letting too much air in. A hanging throttle as you describe is a classic sign of a too lean idle mixture circuit.
Don't just richen out the mixture to fix the problem. Fix the intake gap between the carb and airbox first, then work from there.
http://faq.ninja250.org/wiki/How_do_...dle_mixture%3F
Also if you search the pre-gen tech area for "airbox" you will get some other hits that might help in re-seating the airbox.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old November 13th, 2009, 02:18 PM   #3
nate-bama
North Alabama Mtn. ryder
nate-bama's Avatar
Motorcycle(s): 2006
spend 60 bucks
and see pod thread
and 10 bucks for main jets and a couple flat washers
and see jetting thread
QTRltrPWR
nate-bama is offline   Reply With Quote
Please help, oil in air box. gregoryl 1986 - 2007 Ninja 250R Tech Talk 2 September 19th, 2014 07:01 PM
air box John D 1986 - 2007 Ninja 250R Tech Talk 10 September 4th, 2012 08:07 PM
K&N air filter to stock air box Graugaard 2008 - 2012 Ninja 250R Tech Talk 29 July 28th, 2012 06:33 AM
Air box clamps haze5736 1986 - 2007 Ninja 250R Tech Talk 1 July 9th, 2011 04:16 PM
Air box removed, now.... cbowman78 2008 - 2012 Ninja 250R Tech Talk 6 December 15th, 2010 08:11 AM
