Old April 3rd, 2014, 03:44 PM   #1
peteypetepeep
peteypetepeep's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250
Shimmed my needles, but didn't need to.
Today's project was to shim the needles on my 2009 250r. As first time ever taking off my gas tank, had some difficulties on some hoses & weird clamps. When I got to the carbs, I carefully tried to not strip the screws as everyone had advised, lol. Then when I pulled the cover & spring out. I took out the diaphragm, just to check if it was shimmed already by the previous owner. & Unfortunately, it was & had 2 washers ! Meaning, I didn't even have to go through the trouble of tearing the whole bike down, but hey... I know how to do it for the future. I would make a video the next time I do it, for those who can't seem to trust themselves to do it. I ended up just adding 1 more washer, because my DanMoto Exhaust comes in tomorrow.
peteypetepeep is offline   Reply With Quote
Old April 3rd, 2014, 04:00 PM   #2
DaBlue1
DaBlue1's Avatar
Checking to see if the PO removed the snorkel or not would have been a good hint.
Old April 3rd, 2014, 04:07 PM   #3
peteypetepeep
No, it was stock. I removed the snorkel.
Old April 3rd, 2014, 05:23 PM   #4
DaBlue1
DaBlue1's Avatar
So, how does it ride now?
Old April 3rd, 2014, 05:31 PM   #5
peteypetepeep
A lot better, it was a bit boggy without that third washer. It ran fine with the two washers & snorkel in, but when I took the snorkel out it was .... Ehhhh. So, I should be good when I put my slip-on tomorrow.
Old April 9th, 2014, 06:34 PM   #6
Joshua95
Motorcycle(s): 2009 Kawasaki Ninja 250r
I have couple questions what does shimming? how does it affect the bike?
Joshua95 is offline   Reply With Quote
Old April 9th, 2014, 06:57 PM   #7
The engine burns fuel mixed with air. The ratio needs to be correct for optimal power. As the engine rpm increases, it draws more air through the Intake. To accommodate this, the Carbs must increase the fuel going into the air stream to maintain a correct air/fuel ratio. Our carbs work by using what's called a vacuum slide which uses vacuum from the engine intake to raise a tapered rod called a Needle out of a hole called the Needle Jet. as the needle raises, the space between the needle and the jet increases, allowing more fuel through into the intake. adding a washer effectively raises that needle, increasing the fuel/air ratio. depending on what kind of intake and exhaust setup you have, this could be beneficial or not. with a stock setup straight from the factory, the bikes come a bit lean and adding a washer richens the mix up a bit. these carbs have 3 jets total, the needle jet which i already mentioned. the other two are the Slow-Jet (aka Pilot-Jet) and the Fast-Jet (aka main-jet). the slow jet is very small and is always open. this provides the "minimum" amount of gas that the carbs squirt into the air stream. the Fast-jet is after the needle jet, and limits the "maximum" amount of gas the carbs squirt into the air stream.
so to recap, pilot jet determines the lowest amount of gas going into the air stream which is typically at idle with no throttle. the main jet determines the largest amount of gas going into the air stream which is typically at max rpm wide open throttle. the needle shape and height determine the transition between those two jets.
gasIntoIntakeTotal = slowJet + ( fastJet * (needleTransition+needleHeight))
where needleTransition is 0.0 to 1.0 based on the vacuum range of the engine and the needleHeight is your change from washers or clips which is a percentage of the total needle travel (also in 0 to 1 domain)
Old April 9th, 2014, 09:59 PM   #8
Kscreations08
Fresh Deli Meat
Kscreations08's Avatar
Motorcycle(s): 2009 250R Ninja -Neener-
Guys... Its a serious and informative post from Alex.s Anyone have a thermometer?
We shall call thee "Seahorse." -Antiant on Couvade Syndrome
Kscreations08 is offline   Reply With Quote
Old April 9th, 2014, 10:10 PM   #9
current temperature: Drunk as a Skunk!
Old April 9th, 2014, 10:16 PM   #10
Kscreations08
Fresh Deli Meat
Keep it tipped lol
Old April 10th, 2014, 08:55 AM   #11
Joshua95
Thx Alex for the info I had to look up all the terms you said on google so I could understand more haha
Old April 10th, 2014, 07:26 PM   #12
evidens83
bike noob
evidens83's Avatar
Motorcycle(s): 09 Ninja 250r(sold) 04 Yamaha R6
Nice. I was hesitant at first when I shimmed mine because I felt I wasn't as mechanically inclined as I thought. But all went well and now I feel like I'm that much more closer with my bike now The DIY threads here are awesome!
evidens83 is offline   Reply With Quote
So I shimmed the needles today... ChickenRun 2008 - 2012 Ninja 250R Tech Talk 6 August 25th, 2013 08:09 PM
Shimmed needles/removed the snorkel! NinjaBoyEddy 2008 - 2012 Ninja 250R Tech Talk 5 June 12th, 2012 01:19 PM
Shimmed my needles and discovered something kaiserz 2008 - 2012 Ninja 250R Tech Talk 10 June 6th, 2011 06:36 PM
Shimmed Needles ? overload 2008 - 2012 Ninja 250R Tech Talk 5 October 26th, 2009 01:18 AM
I shimmed the needles and.... :( Gbug 2008 - 2012 Ninja 250R Tech Talk 12 January 25th, 2009 09:14 PM
