May 15th, 2012, 08:24 PM | #1 |
Join Date: Sep 2011 Motorcycle(s): '07 Kawasaki Ninja 250r, red Posts: 21
Top Speeds?
I know this question has been asked a few times but I didn't feel like bumping a thread. How fast have you guys gotten your bikes going (year 2007 or before that is, of course)? Before I wrecked mine, I got up to 111mph on the spedo, and that was at 13k, full tuck, with the mirrors folded in, on a recently paved flat straight highway, no wind, and new Pirelli Sport Demons. I had also just done a valve tune up, synced and tuned my carbs, oil change, new air filter, and chain cleaned and lubed.
May 15th, 2012, 08:32 PM | #2 | |
Join Date: Apr 2012 Motorcycle(s): 2003 Kawasaki Ninja 250R Posts: A lot.
http://www.facebook.com/groups/DeMdNjPagrouprides/ I live my life a quarter mile at a time! Who is affraid of the big bad jiggles???? LOL |
May 16th, 2012, 02:56 AM | #3 |
Join Date: Mar 2012 Motorcycle(s): Suzuki TL1000R Posts: 112
I'm not sure I've ever topped mine out...seemed pointless. It pulls pretty good past 90mph indicated though.
May 16th, 2012, 04:17 AM | #4 |
Join Date: Mar 2012 Motorcycle(s): 2003 Honda Shadow, 2008 ninja 250 Posts: 237
ive had my 2000 to 95 ive also recently gotten a 30mph over speeding ticket so the speed demon in me has been grounded
May 16th, 2012, 04:25 AM | #5 |
MOTM - Sep '18, Feb '16
Just for the record . At this stage the fastest documented speed for a ninja 250 is forum member Shiphteey with his pre Jen going 122.40. The fastest new ninja is my 2008 going 121.8.
Last futzed with by Racer x; May 16th, 2012 at 06:02 AM. |
May 16th, 2012, 05:24 AM | #6 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
I think my record is 108 on a bone stock 2006, which was reading about 118mph on the speedo. Long downhill straight with a tailwind. Unless you've done some serious engine work, pretty much anything over 103mph is going to be due to wind and road conditions rather than your skills at twisting throttle and installing slipons.
Posted via Mobile Device |
May 16th, 2012, 07:18 AM | #7 |
My "max speed" read by my KOSO gauge (which should be perfectly accurate) has it at 110 mph. I can hit 106-107 consistently but the bike ran exceptionally well the day of the 110. I'm also located in flatland Florida but I may have been in a tailwind that day.
May 16th, 2012, 02:05 PM | #8 |
A buddy of mine just topped out his 2006 at 110mph with a gps. Full stock with a bit of a tail wind but flat road. Didn't ask what his spedo read.
May 16th, 2012, 02:42 PM | #9 |
Hmm... You see those numbers yourself. All stock...???
May 16th, 2012, 04:45 PM | #10 |
Its like we are arguing about winning the special olympics...
May 16th, 2012, 05:59 PM | #11 |
http://www.rbracing-rsr.com/gearspeed.html
This is a drive train speed calculator. All you do is fill in the blanks.and it will tell you what the speed you reach for a giver RPM. This is just a math program that says if the engine turns this fast the rear tire is going to turn this fast.It does not take aerodynamic drag into account. fill in the blanks as follows crank 23 flywheel 71 1st 2.60 2nd 1.789 3rd1.409 4th1.160 5th1.0 6th.893 the stock rear tire is about 24.5 inch tall for jack shaft put in 1 for tire growth put in 1 THEN put in your gear ratio. Front 14 15 16 and rear 45 - 39 or what ever you have. It is a fun a powerful tool. you can put in what ever gear ratio and find out where the rev limiter hits and know the bike will never go faster than that. |
May 16th, 2012, 09:04 PM | #12 | |
Milkshake Drinker
http://dmitriy.levchenkov.com/misc/n...pm/index1.html
"What a sweetheart."- ninja_sleeper to me |
May 17th, 2012, 02:18 AM | #13 |
That corrects for speedo error it dose not tell you the exact speed per rpm with what ever gear you have.
May 17th, 2012, 09:38 AM | #14 | |
Milkshake Drinker
The speedo error calculations aren't relevant to the rest of the inputs.
May 17th, 2012, 11:09 AM | #15 |
From what I can see it has actual speed and indicated speed and rpm. How do you know the actual speed?
if you change the rear gear ratio the rpm will change for a given speed. The drive train calculator tells you the mechanical speed for all the gears. And it will allow you to figure out what rpm you would need the engine to turn to go a given speed. My Koso dash has no speedo error. It is also set up for 16 inch rims .With a couple tire choices. Not the actual size of the tire. |
May 17th, 2012, 04:53 PM | #16 |
Join Date: Sep 2011 Motorcycle(s): Cruiser, street, and track Posts: 59
101.5mph GPS. 2008 with full exhaust, Pod filter 107 mains and race bodywork.
May 17th, 2012, 05:07 PM | #17 |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
No idea, I don't have a speedometer.
http://www.simplysurrealphotography....es/peanut2.png |
May 18th, 2012, 05:32 AM | #18 |
May 18th, 2012, 06:22 AM | #19 |
I think maybe it is just one of the stories buddies tell between each other like the fish that got away.
May 18th, 2012, 06:37 AM | #20 |
About 110 is right for a first gen with some mods and a tail wind. I have seen a stock 2003 ninja do over 109 in a mile. But it was like a 30 mph tail wind.
May 18th, 2012, 03:46 PM | #21 |
He is only about 120 lbs but I wouldn't be surprised if he tacked on a few mph to the speed tho. He's getting some Sport Demons in the next day or two so we'll see what it can do after that.
May 18th, 2012, 06:38 PM | #23 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
i got mine to 115mph at the track the other day, full tuck. i only weigh 150 and i have the efi, pods, header and exhaust. Felt like i could keep going lol but who knows. i felt like my limit, i was already on 12.3k in 6th.
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
May 18th, 2012, 06:42 PM | #24 |
May 18th, 2012, 06:46 PM | #25 | |
At Texas World Speedway which uses the nascar straight I only got to 101.5 on my GPS wide open. |
May 18th, 2012, 11:37 PM | #26 |
Im 15/42 and the local track Mussleman. Im actually going to do another track day coming up and i just got new TBs for my efi with a shorter manifold so i could probably go faster.
May 19th, 2012, 03:36 AM | #27 |
115 is awesome . Have you dynoed the bike? 12300 rpm in sixth gear is about 35 hp unless you where going down a hill of coming off some banking.
May 19th, 2012, 10:24 AM | #28 | |
And ha next friday i want to do the same to see if it improved. Also racer x i fiberglassed a race faring that is pretty similar to yours so i do have aero dynamics too on my side. and weight i dont weigh nada ha
May 30th, 2012, 05:34 PM | #29 |
Join Date: Nov 2011 Motorcycle(s): 2009 HD Street BOB 2010 HD Roadglide Posts: 64
[roadracingworld.com] - Marquez Speeds To The Top In MotoGP FP2 In Argentina (Updated | Ninjette Newsbot | Motorcycling News | 0 | April 25th, 2014 03:40 PM |
[roadracingworld.com] - Marquez Speeds To The Top In MotoGP FP2 In Argentina | Ninjette Newsbot | Motorcycling News | 0 | April 25th, 2014 01:30 PM |
[roadracingworld.com] - Top Speeds From MotoGP Free Practice Three At Indianapolis Mo | Ninjette Newsbot | Motorcycling News | 0 | August 18th, 2012 10:40 AM |
[roadracingworld.com] - Thursday's Best World Superbike Top Speeds | Ninjette Newsbot | Motorcycling News | 0 | March 12th, 2009 10:10 AM |
[roadracingworld.com] - Updated: Top Speeds From Saturday Morning's Practice At Red B | Ninjette Newsbot | Motorcycling News | 0 | September 13th, 2008 10:04 AM |
