August 14th, 2013, 09:47 AM | #1 |
Join Date: Jul 2011 Motorcycle(s): 2008 Ninja 250r Posts: 784
Rear light problem?
If anyone could give me some advice on this, it'd be great. My tail lamp stays off for some reason even though it's plugged in correctly. However, when using either brake, it will turn on. I'm not sure as to why. Usually (correct me if i'm wrong) it's supposed to stay on the entire time the bike is running and just brighten under braking. Everything seems to be connected properly :s
Thanks in advance.
Rockin' black on black since 2007. |
August 14th, 2013, 09:50 AM | #2 |
It's a dual filament bulb. If the filament isn't burned out/broken then you have a wiring/poor contact issue.
August 14th, 2013, 09:51 AM | #3 |
Join Date: May 2011 Motorcycle(s): 2006 GSXR 750; 1983 CB750SC Posts: 277
Aren't there two filaments inside the bulb? One element is lit at all times, and the second one is energized only when pressing the brake. I know this is the case for car brake lights, but I can't recall if it was true for this bike as well.
August 14th, 2013, 09:54 AM | #4 |
Ah thanks, that explains it. I'll check after work and see if that fixes the problem.
Thanks
August 14th, 2013, 09:59 AM | #5 |
Yep - new bulb will almost certainly fix it.
August 14th, 2013, 10:15 AM | #6 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
get a new bulb, but go brand name like Phillips or ge. the vibration of these bikes kills bulbs, especially the cheap ones.
and if that doesn't work, buy an R6 |
Rear Brake Problem | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 11th, 2014 05:10 AM |
running brake light problem | Old Lemon | 2008 - 2012 Ninja 250R Tech Talk | 4 | August 13th, 2012 06:40 PM |
Proton light problem | Wesdunkin | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 29th, 2011 09:19 AM |
Strange electrical/light problem | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 6 | July 10th, 2011 02:32 PM |
Rear-Alert Problem | areifel | 2008 - 2012 Ninja 250R Farkles | 4 | May 11th, 2011 04:33 PM |
