Old April 7th, 2014, 05:53 AM   #1
BravoDelta
Motorcycle(s): YZF R15, CBR 250R, Ninja 250R, KTM RC 390
Exclamation head lamp and pilot lamp query
Hi,
own a 2012 ninja 250R and couple of days back realized that the low beam and the pilot lamp is not working. the pilot lamp is also called as "city lamp" in the manual.
The high beam works fine though and i checked to see if the low beam bulb has gone bad but it has not. could this be a fuse issue? if yes, then all 3 should not work right?
Please help/ advice.
Dheeraj
BravoDelta is offline   Reply With Quote
Old April 7th, 2014, 08:12 AM   #2
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Not sure on the headlight....
The city light, if I remember the manual correctly, is hooked in with the license plate light and tail light. Are those working?
If my memory serves and it may very well not, the license/tail/city should be on their own fuse while the headlights are separate.
<-- Linky
Old April 7th, 2014, 08:14 AM   #3
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
Originally Posted by BravoDelta View Post
Hi,
Dheeraj
I have a 2012 but I don't have a city light, but I am in the USA so may be different. Both the high and low beams are on the same fuse so I doubt that is the issue. How did you confirm that the low beam bulb works?
linkinpark9812 is offline   Reply With Quote
Old April 7th, 2014, 08:24 AM   #4
NevadaWolf
NevadaWolf's Avatar
Yep, they are. If you look inside your headlight housing, you'll see a small nickle sized flat disk in the top center. Other countries get a light bulb there.
I found it when trying to locate a wire to tap into that became hot with the bike turned on but not started.
<-- Linky
Old April 8th, 2014, 03:48 AM   #5
BravoDelta
yes the US spec one does not have the city light. I swapped the bulbs and it was working.
I'll be sitting on this issue today and i have a feeling it's nothing major. I'll update the group.
Old April 8th, 2014, 05:15 PM   #6
linkinpark9812
Do you have a multimeter? You can see if there is voltage getting to the headlight plug. If there isn't you can go from there. Really, if the fuse is OK and there isn't some unknown wiring damage somewhere, maybe the high beam switch has gone bad and isn't completing the connection.
Old April 8th, 2014, 07:33 PM   #7
this is what google tells me your problem is:
Old April 10th, 2014, 12:31 AM   #8
BravoDelta
nope. it turned out to be a faulty bulb. I'm not sure how a fused bulb can go on and off. feel silly. For now have swapped the bulbs and using the bike. will get the replacement done in the weekend.so many fake products out here. they even copy the hologram.
LOL, yeah. turned out to be that..funny.
