Old April 11th, 2014, 10:50 AM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
radiator hose size?
does anybody know what size the radiator hoses are & where I might obtain something similar.
thank you very much
mikedabike64 is offline   Reply With Quote
Old April 11th, 2014, 10:54 AM   #2
it's about an inch and you can get correctly pre-bent ones from an oem supplier like bikebandits or cheapcycleparts or you can just get some radiator hose from your local autoparts store and cut it to size.
Old April 11th, 2014, 05:06 PM   #3
mgentz
Board Member
Buy oem. The Chinese silicon hoses suck.
Old April 11th, 2014, 09:22 PM   #4
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
I believe it is 22mm.
linkinpark9812 is offline   Reply With Quote
Old April 12th, 2014, 11:14 PM   #5
mikedabike64
ok thank you
much obliged ty
Anyone try these radiator hose kits? garth285 2008 - 2012 Ninja 250R Tech Talk 4 November 6th, 2014 08:48 AM
Radiator hose into metal tube, why? IF13 2008 - 2012 Ninja 250R Tech Talk 5 May 29th, 2014 04:52 AM
Koso radiator hose adapter JanqeD 2008 - 2012 Ninja 250R Tech Talk 7 May 18th, 2014 12:51 PM
Minor Leak: Lower radiator hose Alkeplar 2013 - 2017 Ninja 300 Tech Talk 11 October 8th, 2013 07:09 PM
carb overflow hose size???HELP 91satanslegend 1986 - 2007 Ninja 250R Tech Talk 10 May 7th, 2012 04:19 PM
