Old May 6th, 2014, 09:40 AM   #1
robbyz
robbyz's Avatar
Motorcycle(s): 2009 ninja 250
need help changed ign.switch,no start
2009 nin 250,changed ign.switch and no sound comes from starter.
robbyz is offline   Reply With Quote
Old May 6th, 2014, 10:09 AM   #2
sonny4472
sonny4472's Avatar
Motorcycle(s): 09 250r, 09 1125r, 95 Virago
Check the 30 amp fuse just under your tank right under the front of your seat. Also, make sure the red harness is seated firmly, it has jumper plugs.
sonny4472 is offline   Reply With Quote
Old May 6th, 2014, 10:15 AM   #3
robbyz
robbyz's Avatar
Thanks so much,maybe from the handlebars hanging?
Old May 6th, 2014, 10:49 AM   #4
robbyz
robbyz's Avatar
the blinkers work the horn does not, in the spark plugs were taken out and put back in
Old May 6th, 2014, 11:11 AM   #5
sonny4472
sonny4472's Avatar
Do your gauges light up?
EDIT
Some simple stuff to check.
Kill switch, starter relay, ign fuse, bike is in neutral with kickstand down, etc.
Old May 6th, 2014, 11:45 AM   #6
robbyz
robbyz's Avatar
No horn,blinkers only,left blinks other stays on,headlight not hooked up,chked battery at my jib 12 and a half volts
Old May 6th, 2014, 12:03 PM   #7
sonny4472
sonny4472's Avatar
Weird. I wish some others would come on with more ideas. Un plug an reattach all your connectors perhaps.
Old May 6th, 2014, 12:08 PM   #8
robbyz
robbyz's Avatar
Remember I have the handlebars , had the handlebars hanging
Old May 6th, 2014, 12:10 PM   #9
sonny4472
sonny4472's Avatar
Ok, maybe it's in your switch housings. Did you remove them or just unbolt the bar mounts? Try temp remounting them and see what happens.
Edit
Pop the switch gear open and make sure nothing has popped loose.
Old May 6th, 2014, 12:43 PM   #10
robbyz
robbyz's Avatar
It pops open?hoq come horn does not blow?
Old May 6th, 2014, 12:43 PM   #11
linkinpark9812
Motorcycle(s): Black 2012 Ninja 250R
If ANYTHING electrical works (not including starter), the 30 AMP fuse is good. Check ALL of your fuses in your fuse box to make sure they are good.
NO START as in the starter does NOT turn over? The starter has no fuse, so it would seem to be a starter problem. However, you have other electrical issues, so I bet the Run switch has an issue, especially since you have been messing with the handle bars. You sure you didn't unplug any harnesses and not plug them back in?
linkinpark9812 is offline   Reply With Quote
Old May 6th, 2014, 03:59 PM   #12
robbyz
robbyz's Avatar
Only headlights in front blinkers,i am home now,the 30 amp is good,how do I pip the switch housing off
Old May 6th, 2014, 04:00 PM   #13
sonny4472
sonny4472's Avatar
It should be two phillips head screws.
Old May 6th, 2014, 04:01 PM   #14
robbyz
robbyz's Avatar
In fuse box only blinkers show on test light
Old May 6th, 2014, 04:08 PM   #15
sonny4472
sonny4472's Avatar
Then you need to trace back to the switches.
Old May 6th, 2014, 04:11 PM   #16
robbyz
robbyz's Avatar
How do i remove right housing,does grip have to be removed?
Old May 6th, 2014, 04:20 PM   #17
sonny4472
sonny4472's Avatar
I don't think so, they should both split in half. I'll look in a few minutes.
EDIT
Confirmed. The screws hold the two halves together. There are a ton of wires/ plugs coming out of both switch gear housings and your IGN switch.
Old May 6th, 2014, 04:30 PM   #18
sonny4472
sonny4472's Avatar
https://www.ninjette.org/forums/showthread.php?t=104619
There is a wiring schematic a few posts down.
Old May 12th, 2014, 02:13 PM   #19
I am not familiar with the anti-theft function but I know that the F-series was updated with one and you may have a mis-matched ignition. As I recall from the ignition key delete thread, the CDI checks for some kind of resistance somewhere before it will allow the bike to run. I would think that the starter would still turn though, but I really wouldn't know. Worth looking into?
Old May 13th, 2014, 04:44 AM   #20
robbyz
robbyz's Avatar
Dropped bike off at mech.He said the ignition I ordered from China is no good,had to splice all wires ,corroded connector.Mech says that Japanese just puut the wires in any hole,so when and the guage of wires is smallerr than factory harness,ordered a ignition from Kawasaki.
Bike won't start using starter switch lilgreenninji 1986 - 2007 Ninja 250R Tech Talk 36 October 31st, 2012 08:28 PM
