Old May 31st, 2009, 11:09 AM   #1
Tubesock
Tubesock's Avatar
Motorcycle(s): 2009 Kawasaki Ninja 250r
Question about oil viewing glass.
Does it matter where the oil level is inside the glass? Right now it's between the 2 fill lines but its closer to the bottom one, is that ok, or is it supposed to be closer to the top line?
"When I die I want mud on my jump boots, magazine empty, and barrel hot."
Tubesock is offline   Reply With Quote
Old May 31st, 2009, 11:12 AM   #2
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Any where in between with the bike off the kick stank and level.
pantera is offline   Reply With Quote
Old May 31st, 2009, 11:15 AM   #3
Tubesock
Tubesock's Avatar
Yea I had it propped up, so that's cool no need to put more in?
Old May 31st, 2009, 11:23 AM   #4
pantera
pantera's Avatar
Should be fine.How much oil did you put in?Bike holds a little under 2 quarts with the filter and oil being changed.
Old May 31st, 2009, 11:25 AM   #5
Tubesock
Tubesock's Avatar
I put 2 quarts and it filled the whole viewing glass but I drained some of it and that how I got it to where it is, and I changed the oil filter as well.
Thanx for the help!
Old May 31st, 2009, 11:27 AM   #6
dmonaco05
Motorcycle(s): 2009 ninja 250r
I would get as close to the top line as possible, that way if any "disappears" you wont be running low
dmonaco05 is offline   Reply With Quote
Old May 31st, 2009, 12:25 PM   #7
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Every bike is just a little different on the internal volume. Book says 1.7 qts with filter; my likes the full 2 qts.
With the bike level you want it between the lines and NO MORE that the top line.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 31st, 2009, 01:12 PM   #8
Verus Cidere
Verus Cidere's Avatar
Motorcycle(s): '91 Honda CBR600 F2
Ok... I've heard a lot of people saying "don't overfill it with oil." I never have and never will, but I'm curious as to what exactly will happen if I do. Why is it such a big deal? I'm a massive noob when it comes to mechanical stuff.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail.
Verus Cidere is offline   Reply With Quote
Old May 31st, 2009, 01:25 PM   #9
It can theoretically cause excess crankcase pressure and blow seals. The world won't end, but it can cause some damage that could be somewhat expensive to repair if you can't do the work yourself.
Old May 31st, 2009, 08:06 PM   #10
doesn't the crank also ride in it too much and start to foam the oil? that's what I heard would happen in the car forums I was on.
Old May 31st, 2009, 08:10 PM   #11
I've heard that, but I think it depends on the particular engine. Some evidently want more oil around the crank than others. ZX-12R's were particularly sensitve about this, and if you overfilled the oil even slightly the hp took a noticeable hit from the crank drag. Seemed weird to me at the time, but it was confirmed over and over again, and even Kawi blamed that issue on one reason one of the mags got a lower than expected top speed out of the bike.
No idea if overfilling the oil on the ninjette contributes to oil foaming due to the crank being in too much oil.
Old May 31st, 2009, 08:13 PM   #12
okay, but I wouldn't want to find out by overfilling.
To the OP, just keep the oil level between the two hash marks on the sight glass when the bike if perfectly vertical and you'll be fine.
Old May 31st, 2009, 08:31 PM   #13
ninjabrewer
dirty old man
ninjabrewer's Avatar
Motorcycle(s): Blue '08 Ninja 250
tubesock, love your signature, (at least its not sand)
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894)
www.friendsofsanonofre.org
ninjabrewer is offline   Reply With Quote
Old May 31st, 2009, 08:33 PM   #14
Tubesock
Tubesock's Avatar
Haha we'll be back in the woods and out of the sandbox eventually.
Old June 1st, 2009, 02:57 PM   #15
Banzai
Psychic war veteran
Banzai's Avatar
We can only hope!
Old June 1st, 2009, 05:07 PM   #16
SF-Dug
SF-Dug's Avatar
I was anal about my oil change and I went out and bought a 1000 ml all purpose plastic scientific measuring container online so I could be exact. These numbers come from the owners manual. You can round off the listed milliliter numbers and still be okay.
1.8 quarts = 1.7 liters (1703.435 ml) - with the filter removed and all is oil drained completely. As in there no residual oil left period.
1.7 quarts = 1.6 liters (1608.800 ml) - when the filter is removed and you are doing standard quick oil change.
1.4 quarts = 1.3 liters (1324.894 ml) - when you do not remove the filter.
With a proper 1000ml measuring container you can always do it correctly. Just make sure it can handle motor oil being pour into it. If you really want a "no worries" measuring container then buy a glass version. I guess doing it this way would take the fun of guessing and checking while changing your oil wouldn't it?
SF-Dug is offline   Reply With Quote
Old June 1st, 2009, 05:11 PM   #17
that's not going to assure you've got the proper amount in there.
it depends on how much oil drained out and how much is still in there in the nooks and crannies, how long you drain the oil... etc, etc.... so many variables. It's not rocket science... just fill it back up so it's between the two lines in the sight glass and be done with it.
Old June 1st, 2009, 06:23 PM   #18
Banzai
Psychic war veteran
Banzai's Avatar
This is one of those times when you REALLY need someone else to hold the bike level for you while you're pouring the new oil in.
Note to self, put filter and drain plug back in and torque to spec BEFORE pouring in new oil.
Old June 1st, 2009, 07:49 PM   #19
lol
Old June 1st, 2009, 08:00 PM   #20
Nickds7
Nickds7's Avatar
I put 1.5 quarts in and then move up from there.. Seems to work great
Nickds7 is offline   Reply With Quote
Old June 2nd, 2009, 05:00 AM   #21
Buffalony
Buffalony's Avatar
Your my new favorite. Thats hilarious.
So in context if we put an excess amount of oil we might be susceptible to foaming + drag?
Too little = better HP worst lubrication?
I think the crankshaft has to be submersed inorder to froth the oil. I believe if your oil level is even just a little high it'll still create windage. I especially notice this on the ninjette. When my oil level is high I get heavier engine breaking compared with when its around the middle/lower of the sight. Unless its high and the oils real hot. Am I crazy? anyone else notice this? Maybe it'll change when I switch to Synth.
Overfilled Oil Sight Glass RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 6 May 25th, 2013 06:11 AM
Oil sight glass BlueHairSar 1986 - 2007 Ninja 250R Tech Talk 20 December 13th, 2012 01:23 PM
Oil sight glass needed. jonnyc Items Wanted 1 August 12th, 2011 07:25 AM
Foamy Oil in Sight Glass??? ScorpionNinja 2008 - 2012 Ninja 250R Tech Talk 19 May 17th, 2010 07:00 PM
Oil Sight Glass empyrean 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2009 10:25 AM
