Old October 21st, 2011, 04:52 AM   #1
ejlover
ejlover's Avatar
Motorcycle(s): Ninja 250R 2011
150/60 Tire For 2011 Ninja (Newly Introduced Tires)
Greetings,
I'm a new member But I was reading the forum for a long time.
I own a 2011 make Ninja 250R (fuel injected). I want to replace my stock tires.
I'll keep the original size 110/70 for fronts but I want a bigger one for the rear 150/60.
I've read all the post about the bigger tire on the forum. But there are no information about the new tires. Mostly all are about Michelin pilot active and BT016.
First of all I won't use my bike on track. Only on road. But the roads in my country are so slippery. So I need a tire that holds the road as strong as possible to prevent a low-side.
I also don't want to force the limits of my rim (like BT003 and BT016 does).
Please suggest me the best tire possible for the front (since it will be in the original size there are many choices).
And best 150/60/17 tire for the rear. (may also be 150/70/17 if it's really better)
Models I have in mind are:
  • Bridgestone Battlax BT-090
  • Bridgestone Battlax BT-021
  • Pirelli Diablo Rosso II
  • Metzeler Sportec M5 Interect
  • Michelin Pilot Power
Bridgestone has information about the actual width and recommended rim sizes about their tires. Bu I couldn't find this information about the rest of the tires. Actual width of the tire shouldn't exceed 156mm. So if you know the actual widths of these tires please share them with me.
I'll really appreciate your suggestions for the best 110/70 front 150/60 rear combination
Best Regards,
Last futzed with by ejlover; October 22nd, 2011 at 09:59 AM.
ejlover is offline   Reply With Quote
Old October 21st, 2011, 05:33 AM   #2
Bols
Norwegian dude
Motorcycle(s): Ducati 748
I live in Norway, so I pretty much need good tires with the colder temperature and all wet weather here. I have been using Pirelli Diablo Rosso, and I really love them! So when the time comes and they are worn out, I will definitely get the new Rosso II's. These tires have gotten very nice results in tests too: Pirelli Diablo Rosso II tests
Bols is offline   Reply With Quote
Old October 22nd, 2011, 12:23 AM   #3
ejlover
ejlover's Avatar
Thanks for the suggestion
But i also need to know the actual tire width of these models. I couldn't find any info about rossoII. If it's larger than 156mm i wouldn't buy it
How are BT090s? I'll probably go with that one because they are suggested for 3,5-4,5 inch rims
Old October 22nd, 2011, 04:19 AM   #4
streetsquid
streetsquid's Avatar
Motorcycle(s): 2011 ninja 250,2005 suzuki drz400 supermoto,2005 cr150f supermoto,2009 klx 110,1998 Z-50
I will be putting a set of
Michelin Pilot Power 110/70/17 and 150/60/17. This winter
I have these on my other bikes and I really do like them. So I am going to stick with them
But it's up to you. You have a lot of good picks on your list
SQUID-Rider who overestimates his abilities.And rides Really slow in the corners,and sudden bursts of acceleration when a straight appears.Squids wear no protection,an thinks there invincible.
streetsquid is offline   Reply With Quote
Old October 22nd, 2011, 10:00 AM   #5
ejlover
ejlover's Avatar
Michelins are a little bit narrow then the others like 151mm but i'll consider them too
Can anyone please share their experiences with the BT090s?
Old October 22nd, 2011, 03:47 PM   #6
Ranor
Ranor's Avatar
Motorcycle(s): 2011 Ninja 250R Pearl White EFI
The Metzeler ROADTEC Z6 are supposed to be ok check them out...
Ranor is offline   Reply With Quote
Old October 24th, 2011, 11:53 PM   #7
ejlover
ejlover's Avatar
But it only has 150/70
Old October 25th, 2011, 05:51 AM   #8
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
don't get to caught up in sizes or thickness...
I'm guessing your Turkish roads aren't the best and a full out sport tire may not be the best idea for everyday riding. You will likely be better off with a sport touring tire that will be better suited for the road conditions. Look at Pirelli Sport Demons or BT-045 in the 140/70/17 rear.
LoneRonin is offline   Reply With Quote
Old October 25th, 2011, 06:23 AM   #9
ejlover
ejlover's Avatar
Okey I've found Sport Demons(150/70) and DiabloRossoII and MetzelerM5(150/60) Which one is better? I don't wanna go up to 70side.
Old October 27th, 2011, 07:41 AM   #10
ejlover
ejlover's Avatar
I've bought the Diablo RossoII. It's not too large like BT003 or BT16 even BT21 is largen then this
Old October 31st, 2011, 04:34 AM   #11
ejlover
ejlover's Avatar
RossoII looks so thin on the bike. People don't even notice the difference
Old October 31st, 2011, 06:02 AM   #12
scotty
scotty's Avatar
Motorcycle(s): Yahama v star 650 classic
Keep in mind, with a bigger tire on the rear, you will not be able to use the whole tire while leaning. Reason being is that the 250r rim is not wide. It was meant for the 130. The 150 tire would be pinched inward. I have a picture on the tire on my old 250r in my profile with a Michelin on.
I would recommend the Michelin Pilot, I have gone though many rain storms with that tire and it still felt great! I have Bridgestone's on my ZX6R, and I don't really like them all that much. That's just me though. I will defiantly be upgrading them come next year.
scotty is offline   Reply With Quote
Old October 31st, 2011, 08:04 AM   #13
Bols
Norwegian dude
You will not get a much wider look unless you change the rims and maybe customize the swingarm. That goes for no matter what 150 you put on there. The rims are not ment to fit 150 tires at all, the only reason to go up to this size is that it's the smallest size most quality radial tires are made in. Rear tires smaller than 150 are usually diagonal, and thats not something you want to be riding on
Old November 11th, 2011, 08:30 PM   #14
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
So is it a good idea to go with the Michelin Pilot Powers? Do they fit on the stock wheels?
NDspd is offline   Reply With Quote
Old November 13th, 2011, 06:37 PM   #15
LoneRonin
LoneRonin's Avatar
yes they fit...I got a 110/150 set up. Great tires.
Old November 13th, 2011, 07:10 PM   #16
NDspd
NDspd's Avatar
That's great to know...I want to go with a better and wider tire. Thanks for the help.
Old November 13th, 2011, 07:30 PM   #17
heylookitsfranco
heylookitsfranco's Avatar
Motorcycle(s): 2008 Ninja 250r, 2006 Ninja 636
+1 for pirelli sport demons. I believe I'm still running 130 but they have so much more grip over the stock dunlop gt501's it's amazing. definitely increased my confidence while turning/cornering.
just my $0.02.
heylookitsfranco is offline   Reply With Quote
Old November 14th, 2011, 10:13 AM   #18
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
i've been thru 2 sets of BT016s in 110/70/17 and 150/60/17. I"ll never use another tire combo on this bike. I love these tires.
kamikaze is offline   Reply With Quote
Fog and slippery roads Rosie General Motorcycling Discussion 14 September 3rd, 2010 07:33 PM
