Old February 11th, 2013, 08:27 PM   #1
jwollam
Bike having trouble starting and running when cold
Hi everyone!
Bike is a 2008 Ninja 250
I was hoping someone could provide me with a few tips. Over the weekend we dang near stripped my bike down to the frame, removed the factory airbox and the clean air system (thank you California!), rebuilt and jetted the carbs (currently with 110 mains @ 3 turns out), and installed a full area P exhaust.
The bike runs great when its warm. However this morning I went out to start it up to go to work (32º outside this morning). I put on full choke and went to start it. It started like normal (with stock everything) However it would never kick up to that high idle (my indication it's okay to ride). The bike just kind of chugged along and would eventually take throttle inputs without wanting to die. Hopped on and started going down the road (had to keep the rpm's low to keep noise down in a residential neighborhood) I got about a mile out and the bike started sputtering and eventually died (I think I flooded it). After a few minutes it started back up and got me to work. Went for a ride at lunch, and it runs like a champ, went again after work and no problems at all.
So after my short novel, here's my question... Is there some trick to get this bike to warm up and ready to ride after putting larger jets in, etc...?
Thanks!
-Johnny
jwollam is offline   Reply With Quote
Old February 11th, 2013, 08:33 PM   #2
Does the bike has a thermostat in proper working conditions?
Did you try with less or no choke?
Old February 11th, 2013, 08:35 PM   #3
jwollam
The fan seems to kick on when it normally should, I don't have any indication that the thermostat isn't working correctly.
Tried it with no choke and it wouldn't start, once running though I was able to take the choke off and it ran fine.
Old February 11th, 2013, 08:47 PM   #4
I asked for the thermostat because it is to remain closed until the engine heats up the coolant around the cylinder and head.
Since that is no much mass of coolant, it should heat up relatively quickly and then force the T-stat to open.
If there is no T-stat or it is stuck open, then the pump forces the coolant to flow through the cylinder and radiator, taking much longer to warm up.
An easy way to test it is to hold the hose going to the radiator during the first moments after start up.
I asked for no choke, thinking that your mix may be too rich with those jets.
Just a couple of ideas.
Old February 11th, 2013, 08:50 PM   #5
jwollam
I appreciate all the help, thank you!
I think it's just trying to get a bike to start up and stay running with this large of a jet (not trying to sound like a newb) It looks like most people start with at least 112's and then move up towards 115's to get the bike dialed in.
I can imagine it's just part of starting a bike with that large of jets. Of course being 32 degrees out in the morning probably doesn't help much either.
Old February 11th, 2013, 08:58 PM   #6
DaBlue1
DaBlue1's Avatar
32 degrees is pretty cold, so your warm up time may be a little longer. Your pod filters don't help the situation much. You now have much more cold air to deal with along with cold fuel. Depending on the weather conditions you could have suffered from carb icing. I noticed the work you did to the carbs, but did not notice if you changed the plugs or not. I would change them to a set of iridium plugs to help prevent fouling and burn the extra fuel you've added a little better.
Old February 11th, 2013, 08:59 PM   #7
jwollam
I'll get a set ordered up tomorrow, thank you for the advice. I think it just has stock plugs in it right now. Is there one particular brand you would recommend?
Old February 11th, 2013, 09:21 PM   #8
DaBlue1
DaBlue1's Avatar
Either NGK CR8EIX or Denso Iridium IU24. The NGK will probably be easier to find locally.
Old February 11th, 2013, 09:25 PM   #9
jwollam
I'll see if I can find the NGK plugs. Do you think I'd benefit from upgrading the wires as well? The wires on the bike are stock, about 5 years old, sat in the Vegas heat for 4 of those years. No indications their faulty, but since I'm doing the plugs... lol
Old February 11th, 2013, 09:41 PM   #10
DaBlue1
DaBlue1's Avatar
If you feel the wires are in good shape, there's no need to replace them. Upgrading the wires or coils will require some modification and a bit of money
Old February 12th, 2013, 06:47 PM   #11
jwollam
So the bike is definitely running rich now. Will pick up some plugs tomorrow and see if I can dial down the mixture some.
Trouble starting bike. Floki General Motorcycling Discussion 56 January 2nd, 2015 03:28 PM
Bike has trouble starting capriccio 2008 - 2012 Ninja 250R Tech Talk 7 July 19th, 2012 10:37 AM
Having trouble starting in cold weather. d16soda 1986 - 2007 Ninja 250R Tech Talk 7 September 20th, 2011 10:47 AM
Problems Starting running a bike danius 2008 - 2012 Ninja 250R Tech Talk 0 October 28th, 2010 05:39 AM
Bike running too cold? Is that even possible? TreyE 1986 - 2007 Ninja 250R Tech Talk 19 October 21st, 2009 04:33 AM
