July 12th, 2014, 04:38 PM | #1 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
Non-Integrated Rear Signal Options
Are there any options for aftermarket rear turn signals that aren't integrated with the tail light? I don't want an integrated one, but I would like something sleeker than the stock ones and with LEDs. All I find when I search are integrated lights.
July 12th, 2014, 04:42 PM | #2 |
Certified looney toon
MOTM Jul '13, Jul '14
Depends on the look you want.
You could get flush mounts and attach them under the tail to be separate from the turn signal. Folks have done LED strips in the tail fairings and wired them up to the turn signal. Hotbodies sells an undertail with turn signals built in. I've even seen license plate bolts that can also be wired for turn signals.
July 13th, 2014, 01:11 PM | #3 |
Hadn't though about LED strips, I'll have to see what I can come up with.
July 13th, 2014, 02:08 PM | #4 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I never wanted an integrated tail until I saw the Custome LED Blaster X. Very clear, very bright. The wife says it's more visible than the OEM indicators, if that is your worry.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 13th, 2014, 06:40 PM | #5 |
July 13th, 2014, 07:45 PM | #6 |
Candy Lime Green
Join Date: Jun 2014 Motorcycle(s): 2012 Kawasaki Ninja 250R Posts: 27
Here's a video of the tail light I just installed a few days ago. I think it looks pretty good.
Link to original page on YouTube. |
July 13th, 2014, 08:22 PM | #7 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
Just to restate what's already been on the board:
Some states require a minimum distance between turn signals like 8.5" |
July 13th, 2014, 08:47 PM | #8 | |
MOTM - June '15
Rear set riser options. | 5evenz | 2008 - 2012 Ninja 250R Farkles | 1 | February 28th, 2013 02:52 PM |
Flush Mount Turn Signal Options - Need Advice | bbjminardo | 2008 - 2012 Ninja 250R Farkles | 14 | February 19th, 2013 07:27 PM |
Integrated Turn Signal - A little puzzled... | Richy_T | 1986 - 2007 Ninja 250R Farkles | 34 | October 9th, 2012 08:38 PM |
[roadracingworld.com] - Pirelli Bringing Five Rear Race Tire Options For World Superb | Ninjette Newsbot | Motorcycling News | 0 | September 18th, 2012 10:20 AM |
Integrated Turn Signal with a twist | jschatte | 1986 - 2007 Ninja 250R Farkles | 46 | July 25th, 2012 08:02 PM |
