June 17th, 2013, 10:49 PM | #1 |
All pigs must die!
front brake line upgrade questions
Finished changing rear brake fluid with no issues cause I didn't need to change the lines as the wiki guide said rubber was better for the rear. But, I decided to buy some stainless steel lines for my front brake as an upgrade.
What size are the bolts that hold the front brake line on a 2008+ ninja 250r? The wiki guide said 14mm(?) but I just wanted to double check. The guide for my new steel lines specifies a torque for the bolts so I want to make sure to get that accurate. And, anyone have any recommendations on a good torque wrench set to get? |
June 18th, 2013, 04:14 PM | #2 |
Board Member
Get a service manual. I think u can even download it here.
Yes most aftermarket lines use bolts with 14mm heads. For torque wrenches I like snap-on |
June 18th, 2013, 04:24 PM | #3 |
Join Date: Nov 2010 Motorcycle(s): '09 250 Street, '09 250 Race, '13 300 Race Posts: A lot.
I'm a fan of http://www.cditorque.com/.
They make Snap-On's torque wrenches and you can get a new CDI for around $120
CVMA #55 |
[webbikeworld.com] - Motorcycle Stainless Steel Brake Line Upgrade | Ninjette Newsbot | Motorcycling News | 0 | April 2nd, 2011 01:40 PM |
[roadracingworld.com] - Performance Upgrade Video: Replacing Front Brake Pads On A Ya | Ninjette Newsbot | Motorcycling News | 0 | December 8th, 2010 10:00 AM |
Front brake upgrade suggestions? | Betlog | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 12th, 2010 09:04 AM |
Front Brake Line Length | Finder | 2008 - 2012 Ninja 250R Tech Talk | 2 | August 17th, 2009 07:48 PM |
