Old April 16th, 2013, 07:24 AM   #1
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
Headlight out
So... My headlights don't work.
  • Turn signals work
  • Tail light works
  • changed the "Head" fuse under the seat
  • Tried new bulbs
It still doesn't work, and I'm not really planning on working on it till I atleast have an idea of what may be wrong and where it is located (relay?). Any ideas?
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old April 16th, 2013, 10:42 AM   #2
caps
Sexy Beast
caps's Avatar
I remember the days when I would post on here and have a response in minuetes. Now I have to actually be patient :-(
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old April 16th, 2013, 11:24 AM   #3
Have a voltmeter? Any voltage coming from the plug?
Old April 16th, 2013, 11:39 AM   #4
Sorry for the many "minuetes" it took me to see your post
Fuse box: There is a 10A fuse (fed by grey wire) dedicated to your headlights.
Headlight circuit relay: It is next to that fuse box. Just follow that grey wire and jump it with the black-yellow wire to verify if the relay is the problem.
Old April 16th, 2013, 11:40 AM   #5
DaBlue1
DaBlue1's Avatar
The headlight relay is the little box black square box at the back of the battery next to the fuse box.
Old April 16th, 2013, 11:45 AM   #6
caps
Sexy Beast
caps's Avatar
Thanks guys
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old April 16th, 2013, 11:47 AM   #7
caps
Sexy Beast
caps's Avatar
I have to find it
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old June 16th, 2013, 07:39 AM   #8
caps
Sexy Beast
caps's Avatar
No voltage from the plug, voltage from the fuse (hot side), and I changed the relay (one was the starter relay). What else do you guys have?
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old June 16th, 2013, 07:29 PM   #9
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
give this a read:
http://www.ninjette.org/forums/showthread.php?t=135883
headlight problems seem to be going around, I just had both low and high beams blow, and relay for fog lights go.
you're gonna need to test a couple things, assuming this is for the 250??
Old June 17th, 2013, 12:29 AM   #10
caps
Sexy Beast
caps's Avatar
Yup. It's the 250. Ill read the link in the am.
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
Old June 17th, 2013, 07:49 AM   #11
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
OP that link posted is my thread. I will be making a write up once I'm 100% sure the problem is fixed. As of right now I believe my headlight relay is bad and the reason my headlights aren't turning on. I did have other problems along the way... like a dead battery that gave me headaches (and is talked about in the thread, so you may ignore that stuff haha).
the relay i'm talking about is:
27002
RELAY-assy
27002-1086
If you have any questions about what i've done I'll keep an eye out here or you can shoot me a pm.
These guys are great and I'm sure saved me some $$$$ at a shop, but more importantly they taught me tons!
gl
walty87 is offline   Reply With Quote
Old June 17th, 2013, 11:33 AM   #12
tsdexter
Motorcycle(s): 2008 Ninja 250R - Kawi Green
same issue
Last week my headlight (high/low) and the high beam indicator went out.. fuse was blown, replaced it and it blew right away.. Please post back when you found the issue.
tsdexter is offline   Reply With Quote
Old June 18th, 2013, 09:03 PM   #13
Asspire
Asspire's Avatar
did ya fix it?
Anyone try this "headlight mesh" to 'reshape' their headlight? iplante 1986 - 2007 Ninja 250R Farkles 9 February 9th, 2013 07:06 PM
Need Headlight Help! NinjaJim5 2008 - 2012 Ninja 250R Tech Talk 3 June 25th, 2011 07:50 PM
Mounting stock headlight and gauges using headlight clamps? SV_Hadder 1986 - 2007 Ninja 250R Farkles 0 January 17th, 2011 09:15 PM
