May 25th, 2013, 09:27 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 2009 Ninja 250R Posts: 206
Replacing front tire on your own?
I'm going to have to change my front tire soon (IRC Road Winner ).
Is this something that I could do on my own with the right tools? If so, which tools and front stand would you recommend to make the job easier? Should I buy rim protectors? Do I have to balance the tire before mounting it? I like doing all the maintenance myself and don't want to pay someone else but I'm afraid this job might not be worth it because people have been saying it's difficult to change tires with hand tools. Thanks. |
May 25th, 2013, 10:08 AM | #2 | |
May 25th, 2013, 12:05 PM | #3 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
The only work that I will not do is mount/balance tires. I don't own the tools nor do I have the patience/effort required to do it properly, so I just pay a shop $20/tire and 5 minutes of my time.
Tools needed would be rim protectors, tire irons, 2x4's (to support the tire so the rim doesn't rub on the ground), bead breaker (you can improvise on this one), and a tire balancer and wheel weights. |
May 25th, 2013, 01:11 PM | #4 | |
http://www.amazon.com/Supply-Nylon-R.../dp/B002LTOZTA http://www.amazon.com/Motion-Pro-08-...e+core+remover http://www.amazon.com/Motion-Pro-08-...ords=tire+iron I don't want to spend $70 on a front stand. Can I just use a floor jack and jack stands to prop the front up? Also, can I use a C-clamp or something else instead of buying a bead breaker? |
May 25th, 2013, 01:18 PM | #5 | |
Yes to the floor jack and C-clamp. I've seen other creative ways to break beads such as running over the edge of the tire with a car or using pieces of wood underneath a car. |
May 25th, 2013, 01:33 PM | #6 | |
http://www.ninjette.org/forums/showthread.php?t=10296 http://faq.ninja250.org/wiki/Mountin...tires_yourself http://faq.ninja250.org/wiki/Tire_Mo...Hints_%26_Tips http://faq.ninja250.org/wiki/How_can...s_by_myself%3F http://faq.ninja250.org/wiki/Reinsta...he_front_wheel
May 25th, 2013, 01:46 PM | #7 | ||
The FAQ says not to use dish soap.
May 25th, 2013, 03:03 PM | #8 | |
You can use a jack under the motor. Just make sure your rear is supported. You could also flip your foot pegs and support your bike with a jack stands and the floor jack under the motor. I use the plastic milk jugs cut up as Tim protectors. Works fine and is cheap.
May 25th, 2013, 03:56 PM | #9 |
Alright so far we have:
1) Valve core remover 2) Tire irons 3) Dish soap + water instead of buying tire lube 4) Cut up milk jugs instead of buying rim protectors 5) C-clamp instead of buying bead breaker 6) Rear stand + floor jack + jack stands to prop the bike up like http://www.dm.net/~bahwolf/co2004/front-off.jpg Am I missing anything? |
June 20th, 2013, 01:43 PM | #10 |
Last futzed with by Bones85; June 20th, 2013 at 05:25 PM. |
[motorcycle.com] - Michelin Replacing Bridgestone as New MotoGP Tire Supplier | Ninjette Newsbot | Motorcycling News | 0 | May 23rd, 2014 08:40 AM |
Does tire need replacing? | Ranor | 2008 - 2012 Ninja 250R Tech Talk | 10 | April 2nd, 2012 11:26 AM |
Replacing front sprocket only | road_rascal | 1986 - 2007 Ninja 250R Tech Talk | 7 | May 29th, 2011 06:56 AM |
Replacing Rear Tire Only? | AgentCircus | 1986 - 2007 Ninja 250R Tech Talk | 11 | July 27th, 2010 02:27 PM |
Replacing Front Springs | Key007 | 2008 - 2012 Ninja 250R Tech Talk | 8 | May 5th, 2010 05:52 PM |
