September 29th, 2022, 02:18 PM | #1 |
[cycleworld.com] - 2023 BMW S 1000 RR First Look
The 2023 S 1000 RR has acquired components and concepts from the M 1000 RR, making it more focused on racetrack riding.
Click here to view on their site. BMW’s 2023 S 1000 RR is more track focused, with modifications to the chassis, engine, and aerodynamics. (BMW/)It was only a few weeks ago that the first hard evidence of a new 2023 BMW S 1000 RR emerged. Now the bike has been officially announced, largely matching our expectations but also showing a few US-specific differences to versions seen elsewhere in the world. M 1000 RR–inspired winglets make their way down to the S 1000 RR. (BMW/)It’s perhaps easiest to start with the most visible update: a set of M 1000 RR–inspired winglets on the nose, applying up to 22 pounds of front-end downforce at high speed. They’re not quite as large as the versions used on the homologation special M 1000 RR, which can manage as much as 36 pounds, but they mean the standard S 1000 RR has now caught up with its winged rivals from Japan and Italy. Further back, and less immediately obvious, is a restyled tailsection with less bodywork than before, helping to give the impression that the bike’s mass is hunched around its front wheel. The styling updates alone might be enough to attract new customers, but BMW has gone much further than that; changes under the skin that include a substantially revised chassis and tweaked engine. The frame retains the old bike’s general design and its idea of tailored flexibility, but BMW has added more holes in the four die-cast alloy members that make up the chassis, allowing it to flex more than the previous version. The chassis has been updated with multiple track-focused features and revised geometry. (BMW/)The geometry is also new, with a 0.5-degree decrease in steering-head angle, now set at 23.6 degrees rather than 23.1 degrees. Alongside new triple clamps with 0.1 inch less offset, the change increases trail from 3.7 inches to 3.9 inches and stretches the wheelbase from 56.7 inches to 57.4. BMW’s adjustable swingarm pivot, previously found only on the M Chassis Kit, is now standard for 2023, allowing more range to tune the chassis to rider tastes while emphasizing the focus on track usage. The changes continue with a revision to the rear suspension, including the addition of a height-adjustable linkage for the shock and a change to the wheel bushings and brake, helping fast wheel changes by keeping the bushings and brake pads in place when the rear wheel is removed. Other rear-end changes include a new rear sprocket that’s grown a tooth, now up from 45 to 46, to reduce the final drive ratio and improve acceleration. Peak power hasn’t changed, but mechanical and changes to the electronics improve rideability. (BMW/)That effort is aided by a revised version of BMW’s 999cc ShiftCam four-cylinder engine. The US model has no change in its peak power or torque, making a claimed 205 hp at 13,000 rpm and 83 lb.-ft. at 11,000 rpm, while the European model gains a couple of horses and a higher peak of 13,750 rpm. Even with unaltered power, the US version has the same mechanical changes as the European bike, with new intake ports based on those from the M 1000 RR, a new airbox, and shortened variable-height intake funnels, again borrowed from the M-bike. Mechanical updates to the engine are matched by electronic changes, notably the addition of a Slide Control function to the existing traction-control system. On the 2023 S 1000 RR, a new steering-angle sensor feeds information to the traction-control computer, allowing it to estimate the drift angle of the bike once the data is combined with that from wheel-speed sensors and the IMU. The 2023 bike’s traction control has settings that allow two drift angles, allowing the rider to sustain more of a slide than would be possible with the previous model before the traction control intervenes. The optional M datalogger can be added as an accessory. (BMW/)The same steering-angle sensor is also key to a similar Brake Slide Control function that’s been added to the 2023 S 1000 RR, allowing the rear wheel to step further out of line under braking than in the past before it’s reeled back in by the ABS. The S 1000 RR further targets track riders, with a new Slick setting for the ABS, specifically intended to work when the bike is fitted with race-oriented tires. A lighter 4.4-pound lithium battery is used for 2023. (BMW/)Other tweaks to the 2023 S 1000 RR include a lightweight battery, a USB port in the rear section, an optional GoPro holder, and a redesigned wiring harness to make removing the license plate bracket easier. The Shift Assistant Pro quickshifter has also been updated for improved gear changes, and there’s a simple process to swap the conventional one-down-five-up shift pattern for a reversed version as preferred by racers and track rats. Of course, there’s no such thing as a free lunch. The 2023 S 1000 RR gets a price hike over its predecessor, with the base model’s MSRP at $17,895 compared to $16,995 for the last of the 2022 models. The $4,495 M Package adds carbon or forged wheels and some additional M parts. (BMW/) S 1000 RR in Racing Red. (BMW/) S 1000 RR in Black Storm Metallic. (BMW/) Rider’s view out of the S 1000 RR cockpit. (BMW/) An optional GoPro mount is available. (BMW/)2023 BMW S 1000 RR Specifications MSRP:$17,895Engine:DOHC, liquid-cooled inline-four; 16 valvesDisplacement:999ccBore x Stroke:80.0 x 49.7mmCompression Ratio:13.3:1Transmission/Final Drive:6-speed/chainClaimed Horsepower:205.0 hp @ 13,000 rpmClaimed Torque:83.0 lb.-ft. @ 11,000 rpmFuel System:Electronic fuel injection w/ 48mm throttle bodiesClutch:Wet, multi-disc back-torque-limiting; cable operationEngine Management/Ignition:Ride-by-wire/TCIFrame:Twin-spar aluminumFront Suspension:45mm Marzocchi inverted fork, fully adjustable; 4.7 in. travelRear Suspension:Marzocchi shock, fully adjustable; 4.6 in. travelFront Brake:4-piston Monoblock calipers, dual 320mm discs w/ ABSRear Brake:1-piston slide-pin caliper, 220mm disc w/ ABSWheels: Front/Rear:Cast aluminum; 17 x 3.50 in. / 17 x 6.00 in.Tires: Front/Rear:120/70ZR-17 / 190/55ZR-17Rake/Trail:23.6°/3.9 in.Wheelbase:57.3 in.Ground Clearance:4.7 in.Seat Height:32.8 in.Fuel Capacity:4.4 gal.Claimed Wet Weight:434 lb.Contact:bmwmotorcycles.com
[cycleworld.com] - BMW M 1000 R Naked on Its Way | Ninjette Newsbot | Motorcycling News | 0 | September 19th, 2022 01:32 PM |
[motorcycle.com] - BMW M 1000 R and Updated S 1000 RR Coming for 2023 | Ninjette Newsbot | Motorcycling News | 0 | September 19th, 2022 09:51 AM |
[cycleworld.com] - 2023 BMW S 1000 RR Updated | Ninjette Newsbot | Motorcycling News | 0 | September 8th, 2022 02:30 PM |
[cycleworld.com] - 2022 BMW S 1000 R Review | Ninjette Newsbot | Motorcycling News | 0 | June 29th, 2022 04:06 PM |
[cycleworld.com] - 2021 BMW M 1000 RR First Ride Review | Ninjette Newsbot | Motorcycling News | 0 | June 23rd, 2022 12:00 PM |
