February 2nd, 2016, 01:20 PM | #1 |
[motorcycle.com] - 2016 Royal Enfield Himalayan Revealed
Indian manufacturer Royal Enfield revealed its much-awaited adventure bike, the Himalayan. Powered by a new 411cc Single, the Himalayan was designed to be a lightweight, uncomplicated motorcycle that can go anywhere, including the rugged terrain of its namesake. In fact, the company’s chief executive Siddhartha Lal proved it for himself, taking some friends and colleagues on some prototypes for a week of riding in the Himalayas last summer. Last month, Lal took a production-ready model on another long trip, riding 500 miles from Goa to Bangalore, mostly on back roads and off-road trails. How’s that for a hands-on CEO? “Himalayan is the culmination of Royal Enfield’s 60 years of enduring history in its spiritual home – the Himalayas,” says Lal. “Our single biggest insight in all these years of riding has been that the best motorcycle for the Himalayas is not one that tries to dominate its landscape, but one that is able to go with its flow. Large adventure tourers that currently define this category do not fare well in the Himalayas as they are very heavy, extremely complicated, intimidating and not really designed for this environment. With its purpose-built ground-up design, the Himalayan is a simple and capable go-anywhere motorcycle that will redefine adventure touring in India.” The Himalayan is a complete departure from the rest of Royal Enfield’s retro-styled standards and cruisers. Every part of the Himalayan is new, including the air- and oil-cooled LS410 engine which boasts an overhead-cam design and a counterbalancer – both firsts for Royal Enfield. With a long*86mm stroke to its 78mm bore, the engine is designed to offer strong torque and usable power at low revs. Royal Enfield claims a maximum output of 23.6 lb-ft. at 4000 rpm while power peaks at 24.2 hp at 6500 rpm. The engine is mounted to a duplex split cradle frame developed by Harris Performance, a British firm acquired by Royal Enfield last May. The 21-inch wire-spoke front wheel is suspended by a 41mm telescopic fork offering 7.9 in. of travel. At the rear, the Himalayan uses a monoshock suspension – a first for a Royal Enfield – offering 7.1 in. of travel. Braking duties are handled by a two-piston caliper with a 300mm disc up front and a single-piston caliper with 240mm disc at the rear. Visually, the Himalayan is rather spartan, with a focus on function over form. Rear luggage mounts can hold either hard or soft panniers while mounting points up front are designed to carry jerry cans, in case you’d like to extend Himalayan’s claimed 280-mile range. The flat seat is 31.5 inches from the ground – fairly low, for adventure bike standards – and the positioning of the footpegs and handlebars allow for an upright riding posture that can easily transition to a standing position for off-road riding. The 2016 Royal Enfield Himalayan will be offered in two colors, Granite and Snow. At the moment, Royal Enfield has only confirmed it will be sold in India, but we’re hoping to see it come stateside. 2016 Royal Enfield Himalayan SpecificationsEngine TypeAir-cooled, SOHC SingleDisplacement411ccBore/Stroke78 x 86 mmCompression Ratio9.5:1Maximum Power (claimed)24.2 @ 6500 rpmMaximum Torque23.6 lb-ft @ 4000 rpmFuel systemCarburettor with throttle position sensorFinal driveO ring chainClutchWet, multi-plateGearbox5-speed constant meshFrameHalf-duplex split cradle frameFront Wheel21-inch wire-spokeRear Wheel17-inch wire spokeFront Tire90/90-21Rear Tire120/90-17Front SuspensionTelescopic 41mm fork; 200mm travelRear SuspensionMonoshock with linkage; 180mm travelFront BrakeSingle 300mm disc; two-piston floating caliperRear BrakeSingle 240mm disc, single-piston floating caliperLength2190 mmWidth840 mmHeight Without Mirrors1360 mmSeat Height800 mmWheelbase1465 mmKerb Weight401 lbsFuel Tank Capacity4.0 gallons2016 Royal Enfield Himalayan Revealed appeared first on Motorcycle.com. Click here for full story...
[visordown.com] - Royal Enfield Himalayan instruments revealed | Ninjette Newsbot | Motorcycling News | 0 | January 13th, 2016 07:20 AM |
[visordown.com] - Royal Enfield Himalayan our best look yet | Ninjette Newsbot | Motorcycling News | 0 | August 7th, 2015 12:51 AM |
[visordown.com] - Is this the Royal Enfield Himalayan | Ninjette Newsbot | Motorcycling News | 0 | April 30th, 2015 04:02 AM |
[motorcycle.com] - Pierre Terblanche and the Royal Enfield Himalayan | Ninjette Newsbot | Motorcycling News | 0 | March 4th, 2015 10:40 AM |
[motorcycle.com] - Royal Enfield Himalayan Trademarked Is this Indias New Adventure- | Ninjette Newsbot | Motorcycling News | 0 | February 9th, 2015 04:20 PM |
