March 17th, 2017, 11:36 PM | #1 |
How to weigh motorcycle.
Let's pretend that an individual was trying to weigh a motorcycle.
Let's also pretend that the individual only had a scale capable of weighing one tire per measurement. Could you put a scale under each tire and add the two numbers to determine the total motorcycle weight? I think the reading would be inaccurate due to the fact that fuel and oil slosh around if the motorcycle is tipped.
Just batshit crazy. All his posts are endless diatribes. Some are actually entertaining but mostly batshit crazy. |
March 17th, 2017, 11:46 PM | #2 |
Track Clown
MOTM - Sep '15
it would work.
or if you have a scale that can weigh over 500# you could place a 6 foot piece of plywood on the scale where it is balanced and roll the bike onto it. |
March 18th, 2017, 06:00 AM | #3 |
Yes that will work. D.O.T. inforcement cops do the same thing when they randomly stop big rigs.
March 18th, 2017, 06:35 AM | #4 |
You can also use one scale to do the job, and put the other wheel on a block of wood to get it to the same height as the scale top. Weigh both wheels separately and add. You can balance the bike upright carefully by hand without pushing up or down if you're halfway careful. You'll see that the scale reading doesn't move around much if you do it right.
March 18th, 2017, 06:55 AM | #5 |
Join Date: Feb 2016 Motorcycle(s): ZZR250, VFR800 Posts: 478
You don't need the block of wood. Assuming your scale is like 2" high the CofG moment is less than 1/2Kg per end. Just make sure you have a ramp up to the scale height that will NOT move, or the scale may tip as you try to roll on to it.
March 18th, 2017, 07:19 AM | #6 |
You will introduce a bigger difference by having more or less fuel in the tank. There is wet weight and dry weight for each motorcycle.
March 18th, 2017, 08:23 AM | #7 |
I suggested the block of wood because my old scale is something like 3" high, and when I calculated the error, it was a couple pounds. Yes, you don't have to use the wood if you're not going for high accuracy. Not that bathroom scales have high accuracy in the first place.
Of course fuel level is very important. 5 US gallons of gasoline weigh about 30 lbs, so if you're trying to lighten the motorcycle and are going to weigh it more than once, have it empty or full each time. I just did a rough calculation, and it looks like if you weighed a 250 on my scale that's 2.5" high without the other wheel being on a 2.5" block, you'd be about 5 lbs low after you add the reading from each wheel. As stated, this isn't a big error, but it's an error. Last futzed with by Triple Jim; March 18th, 2017 at 01:52 PM. |
March 18th, 2017, 02:00 PM | #8 |
Pick it up with both hands, estimate. It works great when I'm trying to win a free lunch at the buffet.
March 18th, 2017, 02:04 PM | #9 |
For me it would be pick it up with both hands and start shopping for an artificial spine.
How's yours doing, by the way? Any improvement? |
March 18th, 2017, 02:13 PM | #10 |
Not much change, but I haven't tried lifting motorcycles recently. I can suggest it to my PT guy.
March 18th, 2017, 07:11 PM | #11 |
Join Date: Feb 2009 Motorcycle(s): 2009 250r SE, 2015 FJ-09 Posts: 171
If you have front and rear stands you can just pick the bike up and set it straight down on the scales if they are narrow enough.
March 18th, 2017, 10:52 PM | #12 | |||
March 18th, 2017, 10:55 PM | #13 | |
Yep yep. Noted. Thanks hernan.
March 18th, 2017, 10:58 PM | #14 | |
March 18th, 2017, 11:06 PM | #15 | ||||
I like your idea much better. Tomorrow I'll see if I can fit a bathroom scale between the front and rear paddock stands that I have. Thank you all for the intel. Somehow you guys think in ways that I don't, and save me a lot of [potentially expensive] trial and error.
March 19th, 2017, 07:37 AM | #16 |
March 19th, 2017, 08:22 AM | #17 |
The sum of the moments about the non-scale side wheel is equal to zero. Boom. Just remember that your scale is measuring normal force (always perpendicular to the floor, in this case directly up), but because your bike is at some small angle, you're actually looking for a component of that to get the weight on that wheel. The angle can be calculated with a triangle made up of rise and run, where rise is the height of your block and run is the wheelbase. You'll need basic trig and some drawings to make sense of it and keep all your conventions straight in your head, that's it.
or... skip the hard stuff, assume a small angle approximation of 1 for your cosine (perfectly legitimate option), and say, "good enough for government work" and take the scale reading for its face value. if your scale is 2" tall and you have this many questions on the math already, the 2" thick scale will make an insignificant difference. or... just put the other wheel on a block that is of similar thickness to the scale. This is likely the easiest method to avoid doing math. Then swap the scale and block to opposite sides so you can get the weight on each wheel. Add them together as a quick double check to make sure your total weight makes sense. #wizardry it's really not that hard. https://en.wikiversity.org/wiki/In_s..._equal_to_zero |
March 19th, 2017, 09:05 AM | #18 |
The biggest source of error comes from the center of gravity being something around 18" above the floor, so that when the motorcycle is higher at one end, the CG moves toward the low end.
March 19th, 2017, 11:51 AM | #19 |
The cosine involved in the sum of moments calculation takes care of that. As the angle of incline approaches 90, cosine goes to 0. So.. For example, if we have the rear on a scale and the front on the ground, if the scale were so thick that the angle of the motorcycle approached 90 degrees from level, the cosine of 90 is 0, so there would be 0 weight on the rear wheel. But that's just an explaination of how cosine works for this. obviously we're dealing with a small angle because the scale is only a couple inches thick, not several feet.
Do one wheel at a time. Sum the moments about the opposite wheel, keep your convention straight and it will get you the weight on each wheel. Add them together and you get the weight of the entire bike. I'm not sure what your method was, Jimjimjim. |
March 19th, 2017, 01:21 PM | #20 | |
March 19th, 2017, 01:37 PM | #21 |
No, I'm intentionally ignoring it to make things simpler. Make the CG inline with the axles (which are what, 11 to 13" off the ground as well?) and the number of equations in your system is greatly reduced because the x component ends up going through the pivot point when you sum your moments and therefore causes no moment.
The block under the other wheel makes this weigh easier, (see what I did there?) but it will be good enough for what it's for if you just assume the CG is inline with the axles of the wheels and everything is square. I guess that's the most pressing question of this whole thing for the OP: how accurate does this weight estimation have to be and what's it for? Because that tells you how in depth you have to go with it. |
March 19th, 2017, 01:45 PM | #22 |
Keep
It Simple Stupid |
March 19th, 2017, 02:54 PM | #23 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Stoppie onto the scales glance down real quick.
Seriously I have done the scale under each wheel thing and it should work but it is inaccurate (or the bike weighs less than spec) and I don't know why. Most councils have a public weighbridge that they use for vehicle laden weight checks etc'. As a taxpayer you should be allowed to use it for ten bucks or so Here is the west of England list. Hawaii resources I cant find googling from here http://www.devonsomersettradingstand.../weighbridges/ |
March 19th, 2017, 06:04 PM | #24 |
March 23rd, 2017, 05:42 AM | #25 | |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
Would work for bikes too. |
March 23rd, 2017, 05:53 AM | #26 |
Extra bonus points to the guy that can pick up a 150Kg motorcycle & still see the scale to get the weight
March 24th, 2017, 10:57 PM | #27 |
VAfish must have a small dog.
For a whopping six bucks I found a hanging luggage scale that reads up to 110lbs. It was great for weighing different wheel/tire combinations but obviously is inadequate for weighing an entire bike. However, it got me thinking (uh-oh.) Does anyone know where I can find a load measuring unit that fits between two pieces of rigging? I know that industrial cranes have them for the purpose of knowing the weight of a particular piece of hoisted cargo. I believe the unit is referred to as a thermocouple, because the sensor actually measures the temperature of a tiny piece of elastic material inside the unit while it stretches when a load is lifted. It's amazing what you can find on ebay from overseas if you use the correct search terms but that is not my specialty. If I could find a unit, about the size of a volleyball or smaller which would fit between two pieces of rope or nylon webbing -- and could measure the force between those two materials for purpose of determining weight, I would be keen on buying it. Basically a "luggage scale" but bigger and with.... say... a 500 or thousand pound weight limit. I could easily construct a sling to lift motorcycle with my excavator, and with a special load measuring unit, I could accurately determine the weight of the bike without any maths. As far as I know, if an object is dangling from an overhead lift point, and the force through the string that the object is dangling from is measured, this will always be an accurate measurement. [Obviously the measuring implement could be miscalculated but let's not over think things.] Thanks for the help and this is all very thought provoking.
March 25th, 2017, 08:04 AM | #28 |
Check these ones out:
http://www.ebay.com/bhp/crane-scale For less money, you can use your hanging luggage scale if inserted in the pulling leg of rope coming from a pulley system: https://en.m.wikipedia.org/wiki/Pulley
March 25th, 2017, 09:39 AM | #29 |
Alternatively find a warehouse or shipping department somewhere that will let you roll your bike up on one of their shipping scales. Or use a truck scale at a truck stop or scrap yard.
March 25th, 2017, 01:33 PM | #30 |
Inspired by this thread, I just weighed my track bike using the bathroom scale method.
Amazing how much weight all the street stuff adds. My R6 in track form with a dry tank weighs just 360 pounds, give or take a couple.
March 26th, 2017, 12:43 PM | #31 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
So just how accurate does one have to be when weighing a motorcycle?
Plus or minus a couple of pounds? Or ounces? |
March 26th, 2017, 07:03 PM | #32 |
March 26th, 2017, 11:25 PM | #33 |
The main reason I asked is because I've been trying different tire/wheel combinations on various bikes and most of the PUC [public utility commision] scales here have incrementations of +/- 20lb. That's not precise enough.
Anyways.. thanks!
March 27th, 2017, 04:57 AM | #34 |
MOTM - Jan '16
March 27th, 2017, 06:23 AM | #35 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
water displacement:
Spoiler for topic:
March 27th, 2017, 07:26 AM | #36 | |
Example 1: In F1, there's a minimum weight limit and every gram counts. So they ballast the cars very precisely to avoid disqualification. There, precision is vital. Example 2: If you're just doing it for chits and giggles, then who cares? When I got my track bike, it felt really light. "Gee," I said to myself, "This feels lighter than my old Ninjette." So I weighed it and found that yeah, it is. There, spitting distance is good enough.
March 28th, 2017, 12:18 AM | #37 | |
Yeah okay, you win. Nowadays scales talk. I must be getting behind on the times.
Is that the travis pastrana x-games bike that was crashed in SF bay? I heard that travis almost re-negotiated his riding contract with suzuki after that stunt and the resulting fine. Things have certainly changed between now and 1999. http://www.sfgate.com/sports/article...es-2919840.php Quote:
Maybe I need to buy new motorcycle. Again.
March 28th, 2017, 06:46 AM | #38 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
Go to your local recycling station:
March 28th, 2017, 10:08 AM | #39 |
+/- 20lbs ^^^
March 28th, 2017, 10:18 AM | #40 |
06 R6 - 161kg
08-12 250r -151kg ...according to wikipedia.
[topix.net] - My Motorcycle Weighs 40 Pounds, How Much Does Yours Weigh? | Ninjette Newsbot | Motorcycling News | 0 | August 13th, 2010 10:30 PM |
How much does a stock exhaust weigh? | ScorpionNinja | 2008 - 2012 Ninja 250R Tech Talk | 3 | August 4th, 2010 01:19 PM |
[topix.net] - Final weigh-in photos | Ninjette Newsbot | Motorcycling News | 0 | May 26th, 2010 03:10 PM |
[topix.net] - American motorcycle safety experts weigh in on European study | Ninjette Newsbot | Motorcycling News | 0 | April 27th, 2009 10:30 AM |
[motorcycledaily.com] - Weigh in on Ben Spies Fast Start | Ninjette Newsbot | Motorcycling News | 0 | March 17th, 2009 12:40 AM |
