March 30th, 2017, 11:24 AM | #1 |
no power
Had bike on turned it off, now it won't turn on no lights on the gauges turn on ,battery is good any ideas.taillight turns on blinkers lighting up T
March 30th, 2017, 11:30 AM | #2 |
Get out a meter or test light and see how far you have power as you move away from the battery, starting with main fuse.
March 30th, 2017, 11:31 AM | #3 |
Main fuse would be something to check, as would the battery terminal connections.
I'd also check the battery voltage both before and after you turn the ignition on. A battery can sit at a normal voltage until any amount of load is put on it (even just turning on the ignition) and then drop to zero. |
March 30th, 2017, 11:50 AM | #4 |
safety switches bro
start with sidestand switch, i bet it's dirty, then make sure your battery terminals are clean and tight
March 30th, 2017, 12:45 PM | #5 |
blown fuse
Blown ignition fuse changed it gauge lights came on but didn't crank over then fuse blew again any ideas
March 30th, 2017, 01:30 PM | #6 |
There's something causing excessive current draw. It could be a wire that got its insulation chewed through and is touching the frame, or a defective switch. Once I had a rear brake light switch go bad and randomly blow fuses. I ended up replacing the fuse with a non-auto-reset circuit breaker so at least I didn't have to carry a dozen fuses with me to go for a ride. I eventually found the bad switch when it became obvious that the fuse seemed to blow only when I used the rear brake.
March 30th, 2017, 01:46 PM | #7 |
I'm not sure I follow that, Hernan. The starter motor isn't fused, so it can't be causing fuses to blow.
March 30th, 2017, 01:56 PM | #8 | |
I believed it was Previous post deleted. Thanks
March 30th, 2017, 02:07 PM | #9 |
The starter solenoid is supplied through the main fuse, so if it has a problem it could blow the fuse when attempting to start the engine.
March 30th, 2017, 02:37 PM | #10 |
OK now I need to locate the starter and find a place to get another one if it's faulty
March 30th, 2017, 02:52 PM | #11 |
If the fuse on the starter solenoid isn't blown does this mean the solenoid OK . I keep popping the 10 amp ignition fuse.
March 30th, 2017, 03:05 PM | #12 |
If you're blowing the 10A fuse, it means something after that is drawing too much current. As I said, look for chewed insulation, a faulty switch, etc..
No need to start a new thread. It'll make your answers spread out in two places. |
April 12th, 2017, 09:59 AM | #13 | |
One ugly son of a gun.
HOWEVER... don't just toss a 30amp fuse in there- if it's supposed to be a 10 amp fuse then it will not offer the protection it was designed for. |
[sportrider - latest stories] - New Michelin Pilot Power 3 And Power Supersport Tires | Ninjette Newsbot | Motorcycling News | 0 | May 9th, 2013 05:30 PM |
[topix.net] - Eco Wave Power developing two new wave-power devices | Ninjette Newsbot | Motorcycling News | 0 | January 9th, 2012 06:40 AM |
Loss of power on highway (all the power) | aldenso | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 7th, 2011 10:27 PM |
[motorcyclistonline] - Power to Spare with New Snap-On 12-Outlet Power Strip | Ninjette Newsbot | Motorcycling News | 0 | October 1st, 2010 03:40 PM |
Power question, powerlet 12v to mini-usb power. | karlosdajackal | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 12th, 2010 05:03 AM |
