December 25th, 2009, 05:54 PM | #1 |
Question on Shogun Sliders + Carb clearance.
Hi everyone, I'm thinking of picking up the Shogun frame sliders (http://www.kawiforums.com/ninja-250r...tallation.html) but will also eventually rejet my carbs. Question, from those images above, will the slider "bars" block the carbs so that it would require me to remove the sliders everytime I want to tune my carbs? I just got the bike so am not familiar with its anatomy as of yet. Thanks in advance everyone.
December 25th, 2009, 06:55 PM | #2 |
I'm not sure if they will block, but some other folks who have experience with the Shoguns have posted up in the wiki here, and there are some related threads.
Here's a link to the wiki section, and here's one of those threads.
December 25th, 2009, 07:17 PM | #3 |
Join Date: Jan 2009 Motorcycle(s): '08 Ninja 250 R.I.P. Posts: 84
I put them on my wife's bike. I removed the carbs for shimming and tweaking. It was a little bit of hassle but it came out after some twisting and turning. Drain the carbs first, ask me how I know.... But no you don't have to remove the bars to get the carbs off. Good thing too as I only had Loctite red when I put them on.
December 25th, 2009, 07:32 PM | #4 |
Thank you both you have both been very helpful!
December 25th, 2009, 07:46 PM | #5 |
self wrencher
I just rejet my bike today with ( drill a hole in slider). Shogun doesn't block at all. Pulled out carb/clean/rejet put back in about 1 hour.
Posted via Mobile Device |
December 29th, 2009, 09:29 PM | #6 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 118
I removed my airbox, so the Shoguns are no problem, since I pull my carbs from under the seat.
December 29th, 2009, 10:43 PM | #7 |
Can I pull the carbs out from under the seat without having to remove the airbox entirely off the bike? That is, just leave it within the bike, dangling.
Last futzed with by Betlog; December 30th, 2009 at 12:00 PM. |
Question regarding ground clearance (pregen) | Sirref | Ninjettes At Speed | 19 | May 24th, 2014 09:44 PM |
Which Shogun Frame Sliders? | solo440 | 2008 - 2012 Ninja 250R Farkles | 7 | July 15th, 2011 05:13 AM |
*LIKE NEW* Shogun Frame Sliders | 00v_Lucky | Motorcycle-related | 11 | July 2nd, 2010 04:35 AM |
Do shogun sliders get in the way of carb removal? | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 29th, 2010 07:53 AM |
Shogun Sliders and Vibration | ninja11 | 2008 - 2012 Ninja 250R Tech Talk | 19 | July 29th, 2009 08:35 PM |
