Old December 3rd, 2017, 01:14 PM   #1
Thomas linnell
Ranger tom
Motorcycle(s): Ninja Gpx 250
Bike won't crank - New battery
I just got a ninja 250 that had Ben setting for awhile I got a new battery poot it in the nutrol, oil and the middle tale light come on but when i het the ignishen switch nothing happeneds
Thomas linnell is offline   Reply With Quote
Old December 3rd, 2017, 01:42 PM   #2
Hi and welcome Thomas!
Do you have-
- FSM - field service manual with electrical wiring diagram?
- multimeter?
Please review this thread:
https://www.ninjette.org/forums/showthread.php?t=307592
Old December 3rd, 2017, 02:13 PM   #3
Thomas linnell
Ranger tom
That was help full I'm about to go over to my papas to work on the bike I'm shore I'll have more questions this is my first bike
Old December 4th, 2017, 01:28 AM   #4
Bluberryrain
Bluberryrain's Avatar
This happened to me a while back:
https://www.ninjette.org/forums/showthread.php?t=300192
It ended up being a loose electrical connection (plug) under the gas tank, on the right side of the bike.
From @Flying:
Test the relay by short circuiting the terminals under the fuse with the screwdriver, make sure to not touch the frame.
If the starter turns over, then you need to inspect all the wiring originating from the 4-pin plug (red cover).
https://www.ninjette.org/forums/show...3&postcount=26
Wiring diagram, see the fuse/motor/battery group at the bottom right, follow it upwards to the other starter relay. Look for burnt wiring or plugs.
If the starter does not turn over, there is a problem with the relay itself, the motor, the negative/positive wiring leading to the two terminals on the relay, or the battery.
I suggest you follow his steps above with the diagram. He helped me solve the issue in minutes, when I had already spent hours.
Bluberryrain is offline   Reply With Quote
Old December 5th, 2017, 06:44 PM   #5
Thomas linnell
Ranger tom
It was the starter solenoid but I found out that the carbarater is mixing my gas in to my oil so I have to Chang the oil be for starting it but I was grad to finally here she make a sound
Old December 5th, 2017, 06:47 PM   #6
Thomas linnell
Ranger tom
It's like the coper pen is not going all the way down is what the guy that I bought it from told me was one of the issues
Old December 5th, 2017, 06:50 PM   #7
Thomas linnell
Ranger tom
That leank you poor in there is not working
Old December 5th, 2017, 09:01 PM   #8
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
It does, in the original post.
<-- Linky
Old December 6th, 2017, 09:49 AM   #9
:waves: hiiii
Old December 6th, 2017, 01:55 PM   #10
NevadaWolf
NevadaWolf's Avatar
Hewwo!
<-- Linky
Old December 9th, 2017, 12:00 AM   #11
Thomas linnell
Ranger tom
Well I have a 1988 gpx ninja 250 so will the wirking be the same as a 2008 ninja 250 shown on the diagram
Old December 9th, 2017, 04:20 AM   #12
No, not same. Here's correct diagram for 1988-2007:
https://faq.ninja250.org/wiki/Starter_circuit_schematic
1. Note that there's 4 switches that must be set properly for START button to work.
- Ignition-switch = ON sending power out
- Engine Start/Stop = ON
- Neutral-switch = ON or...
- Clutch-switch = IN (squeeze lever)
2. There should be +12v power on red wire going into START button
3. There should be continuity/zero-resistance to chassis-ground on yellow/green wire at starter-relay coil
ONLY when ALL these switches and conditions are set properly will START button activate starter-relay which activates starter-solenoid which sends power to starter.
Old January 5th, 2018, 04:32 PM   #13
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Fuel mixing into oil huh? Been sitting a while, likely piston rings are, or were seized.
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Bike won't crank, lights come one, replaced battery and solenoid starter. iforgot 2008 - 2012 Ninja 250R Tech Talk 4 November 21st, 2015 12:35 PM
Starting issues, Ninja 2010 won't crank BlueDragon 2008 - 2012 Ninja 250R Tech Talk 6 March 12th, 2015 02:49 PM
Another bike will crank but won't start thread... remix919 2008 - 2012 Ninja 250R Tech Talk 10 May 12th, 2014 01:05 PM
bike won't crank!! LoneRonin 2008 - 2012 Ninja 250R Tech Talk 14 September 5th, 2011 04:19 PM
New battery, still won't start frankfong 1986 - 2007 Ninja 250R Tech Talk 9 January 12th, 2011 10:08 AM
