Old October 31st, 2017, 09:38 AM   #1
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
Possible coast enricher failure??
Hello guys and gals. Short story.
I have a 2009 with 8,000 miles. I bought an area p system and started jetting the carbs. I have never been able to get them right. And the header glows red, So bike has been parked for two years. With gas in it. Damn. It just got pushed to the back burner and I never got around to working on it. Life got in the way, whatever.
So I was reading online and came across an article and the guy said to be sure not to get any carb cleaner on the diaphram on the coast enricher. I probably did, and without tearing it down I won't know for sure. And it needs to be torn down and cleaned anyway.
So my question is: What happens if the diaphram in the coast enricher housing is ruptured or other wise leaking?
I decided to sell my ninja 650, so I'm going to finish up this 250 and let that be my street bike. Yeah, it came down to the 250 that hasn't been ridden in years , or the 650 that has given me 26,000 miles of reliable travels. I love the 250, so I decided to keep it and sell the 650.
Thanks for any help.
gantt is offline   Reply With Quote
Old October 31st, 2017, 01:44 PM   #2
Ceeloo Yello
Motorcycle(s): 250
I was always told that when a header glows red that means a lean condition but back to your question they do sell that diaphram at the dealer.
Old October 31st, 2017, 02:16 PM   #3
Ram Jet
Ram Jet's Avatar
What's the engine speed when the headers glow red? It sounds like you have an extreme lean condition. Your piston crowns and exhaust valves may be at risk also. Carb cleaner will probably damage all the diaphragms in your carburetor. Have you modified your jet needle height/setting? What size main jets are you running? I expect that if your coaster enricher is malfunctioning your engine will backfire on deceleration.
Bill
Old October 31st, 2017, 02:20 PM   #4
Both lean and rich conditions can result in glowing headers. Most common cause I've found is due to combustion burning after the exhaust-valves open. This was due to having extra fuel so that combustion lasts longer than normal. And having retarded ignition so that total combustion time extends into exhaust-valve opening period.
Simple enough to test diaphragm to see if it holds or does not hold vacuum applied to it.
Old October 31st, 2017, 02:59 PM   #5
Agreed, overly rich can result in fire in the head pipes, making them glow.
Old October 31st, 2017, 05:15 PM   #6
ducatiman
ducatiman's Avatar
The enrichener diaphragm is super thick, double sided (over a fabric)... a shot of carb cleaner not likely to "hole" it (to be avoided, nonetheless)
In the extreme storage conditions you describe... you must expose and examine it. Remove any rust or particles and also suggest to polish its little brass shaft slider bushing...metal polish is ok....no stiction or hanging up, free to float in and out. Using compressed air, assure all housing "ports" are clear. Don't lose the special, tiny housing oring!
Vacuum actuated...the long spring provides preload and secures it in its "home position"....vacuum pulls it out on decel....
As you know. no less than 4 vacuum hoses connect to it.....3 top, 1 bottom each ported to tiny openings within the housing.
A strange scenario.....differing with throttle positions .....but I'd surmise an actual ripped diaphragm would produce a weird vac leak, likely pulling some additional fuel from the mixing chamber, too.
Sorry for run-on.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old October 31st, 2017, 08:05 PM   #7
gantt
gantt's Avatar
Thanks guys. I don't remember what jet sizes I used last, but I did exchange emails with Kerry at Area P, and he gave me a good base line to start at.
I'll get the carbs disassembled soon and replace the rubber parts and give it a good cleaning.
Poor thing been parked for too long.
The plus side is, in the two years it's been parked my mechanical skill has gone up tremendously. Really was fumbling my way through it last time. I'll probably go already and order the enricher diaphram while I am at it.
Old November 8th, 2017, 10:50 AM   #8
NinjaBraap
NinjaBraap
NinjaBraap's Avatar
Motorcycle(s): 06 Ninja 636, 2016 Yamaha R3 (Street/Track), 2019 Ninja 400 Project Racebike
Glad you found some help on that. You're definitely running super lean and as someone pointed out if your headers were glowing red the structural integrity of the metal components inside is at best questionable now. It's too bad you didn't just do the valves on the 650 along with all other maintenance and keep riding until overhaul time, wouldn't have to deal with the stress of carb finickiness (I'm assuming it was a ninja 650 and not KLR or older SV). I loved my 650 and rode it from 12k to 38k until I traded it for a Miata.
Racer, Mechanic, Enthusiast. Vendor for Norton Motorsports
Subscribe to my Instagram and YouTube: Instagram
YouTube
NinjaBraap is offline   Reply With Quote
Old November 17th, 2017, 01:53 PM   #9
gantt
gantt's Avatar
i never did the valves on the 650, but kept riding it. 250 has not been fired up since late 2014, best i can remember
Old November 17th, 2017, 05:52 PM   #10
ducatiman
ducatiman's Avatar
As an aside to the subject "decel valve failure", I had occasion to work on a Yamaha TT125 single cylinder dirtbike. Beyond other unrelated issues, the idle was unstable...all over the place.
Upon carb disassembly, I found the decel valve diaphragm locating spring was missing....the diaphragm uncontrollably "flapping in the breeze". Upon replacement...starts 1 kick, flicking the throttle met by good response and a quick return to a rock steady idle.
Always a good idea to give an eyeball while on the bench, incorporating inspection within a carb service.
Custom Carb Service
Last futzed with by ducatiman; November 18th, 2017 at 06:54 AM.
Old November 17th, 2017, 10:19 PM   #11
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
if ya have a full system check the jetting database. this will give a reference point on where to start. buy a jet kit. good luck
"trying not to get old"
Old November 21st, 2017, 04:04 AM   #12
gantt
gantt's Avatar
I bought a dyno jet kit when I bought the exhaust. I did order a set of bowl o rings for a z750 Buying them like that I was able to buy a four pack for $18. Cheaper than buying the same o ring in a single pack for a 250r for $12. So I have what I need to disassemble and clean the carbs, and start the jetting process. I think I am going to work on the 650 first. I have a few things I want to tidy up before I sell it. After it sells, I am going to rebuild the forks on the 250. Will be going with racetech springs. Not looking to get wild, but I remember the front end being soft. I'd rather redo it and adjust it for my weight while I am at it.
Coasting enricher, what pipe goes where? RBN 1986 - 2007 Ninja 250R Tech Talk 2 July 9th, 2013 02:45 AM
The Ultimate Antique Bike Endurance Event: Coast to coast on 95 years old motorcycles Motofool General Motorcycling Discussion 2 April 24th, 2013 01:14 PM
[motorcyclistonline] - Kane Friesen Takes the Vulcan Vaquero Coast-to-Coast Ninjette Newsbot Motorcycling News 0 October 28th, 2011 02:10 PM
[topix.net] - Kane Friesen Takes the Vulcan Vaquero Coast-to-Coast Ninjette Newsbot Motorcycling News 0 October 28th, 2011 02:10 PM
[topix.net] - Coast to coast motorcycle enthusiasts raise money for children's charit Ninjette Newsbot Motorcycling News 0 May 4th, 2010 06:00 AM
