Old November 26th, 2017, 10:44 AM   #1
ScubaSteve
Motorcycle(s): 2005 Kawasaki ninja 250
Exclamation Gas tank needed!!!
gas tank needed!
does anyone know of a 2005 ninja 250 gas tank for sale that does not have rust inside tank?
i am having a very hard time finding a good condition tank, anyone know where to find a new tank?
ScubaSteve is offline   Reply With Quote
Old November 26th, 2017, 01:32 PM   #2
Due to age, any tank is a rust risk. I almost bought brand-new never-used tank for $600 from shop that found it at back of shelf, score!!! When they brought it down, i opened box and it was hallelujah moment, it was so beautiful, birds sang and angels wept! I opened cap... and... entire inside was rusty!! With any tank you get, you'll want to restore it:
- remove rust with phosphoric acid rust remover. Do not use vinegar or muriatic/hydrochloric or oxalic acids. Those do not differentiate between rust and good metal and will eat hole through tank. Phosphoric acid will also leave a protective phosphate coating on surface.
- coat with plastic liner material such as Caswell, Kreme, POR-15 or Red-Kote. Some people have just used epoxy fibreglass resin diluted slightly.
After this is done, you've got good-as-new tank you won't have to worry about.
Last futzed with by DannoXYZ; November 26th, 2017 at 08:02 PM.
Old November 27th, 2017, 08:46 AM   #3
"A"
vampire
Motorcycle(s): 2 many 2 list
Pre-gen fuel tanks should be easily available in your local motorcycle salvage yards in FL.
"A" is offline   Reply With Quote
Old November 27th, 2017, 05:30 PM   #4
teafour
Corner Chaser
teafour's Avatar
Motorcycle(s): 2006 GSXR1000, 1986 VFR750, 2004 Ninja 250
There's several tanks on ebay right now. I'm sure a few should be acceptable level.
teafour is offline   Reply With Quote
Gas Tank Lock stuck? Maintenance for gas cap with pics! Skippii 1986 - 2007 Ninja 250R Tech Talk 35 May 6th, 2021 09:03 PM
How does a gas pump shut off automatically when the gas tank is full? Motofool General Motorcycling Discussion 4 August 2nd, 2015 04:12 PM
Replacing CA gas tank help needed cferris08 2008 - 2012 Ninja 250R Tech Talk 3 June 24th, 2014 11:33 PM
