Old August 21st, 2019, 09:10 AM   #1
Bills dad
Motorcycle(s): Kawasaki ninja ex250
Highway?!!
So dumb question, haven't taken her out on the highway yet being I just got a new tire. However good is the 250 for the long haul and what's a pretty safe speed mechanical wise, are they good for short trips , longer ones? I'm planning an out of town ride about an hr out, and I figure around 65 to 70 there, any thoughts or pointers?!
Bills dad is offline   Reply With Quote
Old August 21st, 2019, 09:29 AM   #2
Our 250s have no problems with highway trips. There are guys here who do cross country steady 70+ mph trips on them. Treat yours like any other capable motorcycle and have fun! When I had the stock fairings on mine it did notice a little more effect of crosswinds than with my larger motorcycles, but nothing that was hard to manage.
Also enjoy the 60+ mpg they're capable of when running right. Mine often gets in the mid-upper 60 mpg range on longer rides without a lot of starts and stops. It has a bone stock engine, airbox, air filter, carbs and exhaust.
Old August 21st, 2019, 09:34 AM   #3
I've done 3-day road trips on mine. Highway, back roads, do it all. No problem. Packed camping gear on her, water, everything. These bikes are pretty capable.
Old August 21st, 2019, 09:48 AM   #4
I've taken mine on trips between San Francisco and Santa Barbara. That's about 5-hrs if I take boring hwy-101. Or about 6.5-hrs on more scenic hwy-1 along coast. No problems whatsoever.
Old August 21st, 2019, 10:02 AM   #5
Ralgha
Ralgha's Avatar
It does fine with long distance, but I've never gotten more than 50mpg with mine. Probably because I ride it like I stole it.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old August 21st, 2019, 11:53 AM   #6
AwDang
A Ninja 250 completed the Iron Butt Rally
Old August 21st, 2019, 12:15 PM   #7
Bills dad
Thank you for your input. I prefer to ride her like I want to keep owning her, I know she's getting bad milage in town, but that's alot of stop and go and I'm running the premium. K and N air filter and a TIGA exaust. I also know on the highway I won't get the best milage being she's got a 140 rear instead of the stock 130. Again thank you all for your input!!!!
Old August 21st, 2019, 12:36 PM   #8
You should still get decent mileage, even with a K&N and aftermarket exhaust - depending on how you ride it.
My 650 will get 50 mpg in-town, or at about 70 on the hwy, without trying. You should be able to best that with the 250. It drops quite a bit when I cruise around 80 though.
Have you made mixture adjustments to the carbs with shims or jets?
If you haven't increased compression you don't need to run Premium. Extra octane will reduce power and mileage. Can you get ethanol-free 87?
The larger rear tire shouldn't effect hwy mileage. Going up 1 tooth on the countershaft will settle the engine down a bit at hwy speeds, but there is a price to pay in-town in reduced acceleration. Some people don't mind the trade-off, others think it's too much.
Old August 21st, 2019, 02:12 PM   #9
Bills dad
As far as I know everything is stock on this bike mechanical wise. I believe here we got 87 90 and 93. I figured running the cheap 87 wouldn't be good for it. And would get less performance. But an aquantance was mentioning one of our stations has a gas called clear so I'll have to check that out.
Old August 21st, 2019, 02:44 PM   #10
Octane is a measure of how fast it burns, not quality. You need to match the octane to the speed your engine is tuned for. They call it 'premium' but it has absolutely no meaning aside from octane number.
Old August 21st, 2019, 02:47 PM   #11
Ralgha
Ralgha's Avatar
The Ninja likes 87 octane just fine. Not to mention, most people buy regular gas, so it's the freshest gas at the station. When it's got ethanol (which it usually does), that can be a big factor.
Old August 21st, 2019, 02:49 PM   #12
For what it's worth, all I put in my 250 is 87 octane with "up to 10% ethanol added".
Old August 21st, 2019, 03:54 PM   #13
If it's tuned for 87, anything else will give you worse performance. Ethanol can be in any octane but hard to avoid. I haven't found any stations here where I've noticed it's clean.
Old August 21st, 2019, 04:08 PM   #14
Some people have no choice but to use gas with ethanol (E10). To get it to run the best possible on E10 you need to richen the mixture. The idle mixture screws should be adjusted out slightly and a shim under the needles wouldn't hurt, but the stock Main Jet is too rich anyway - so it may even run better wide-open on E10.
I can get 87 without ethanol locally, so it's all I run in my cycles and small engines. Ethanol contains and hold water, so I avoid it for anything with a metal gas tank.
Old August 21st, 2019, 04:45 PM   #15
About 3-hrs away for me to find ethanol-free petrol. I just use E10 87-oct just fine on all Ninjettes as that is what's recommended in owner's manual.
I've got some articles and links to real octane info rather than common urban-legends if anyone's interested.
Old August 21st, 2019, 05:00 PM   #16
What are the common urban legends?
Old August 21st, 2019, 05:16 PM   #17
I can too, but it's a buck or more extra per gallon. In the last ten years I've run nothing but E10 in my motorcycles. I have seen no evidence of rusting in any tank, or any other problem related to the alcohol. I do keep the motorcycles in an air conditioned and heated garage though, so there's not as much moisture around as there would be if they were in less kind quarters. The E10 is what gets me the upper 60s gas mileage too.
Old August 21st, 2019, 06:48 PM   #18
nocturncal
nocturncal's Avatar
Motorcycle(s): '09 Ninja 250R
It can handle the highway. I've road tripped from San Francisco to San Diego/LA and it was great! The only thing I'd say is that the ninjette will get pushed around with high winds, but it's not like you'll go down because of that.
MPG is a beast, like 55-60mpgish for me, if your on the freeway moving with traffic, don't plan on gunning the throttle to pass cars, it takes a bit more finesse and planning if you're tryna maneuver and bypass traffic.
Old August 22nd, 2019, 01:09 AM   #19
Yeah, any time you brake or increase throttle, it decreases your MPG. There was guy that got 90mpg out of Ninjette. Did extreme hyper-miling techniques such as going 50-60mph on freeway or EOC on off-ramps. I don't have time for that kind of stuff. Getting 50mpg is just fine!
Last futzed with by DannoXYZ; August 22nd, 2019 at 02:20 AM.
Old August 22nd, 2019, 01:47 AM   #20
That "higher-octane petrol burns slower". Flame-front propagation speed will vary in an engine based upon compression-ratio, throttle-opening, RPMS, etc. However, on exact same engine under same operating conditions, combustion speed will be exactly same ~16.5m/s for both 87 or 91-octane petrol.
The exact opposite is true. Higher compression, larger throttle openings and higher-RPMs results in faster combustion speeds and more power. Similar to black-powder vs. modern smokeless gunpowder, faster combustion generates more power. Oxygenated fuels like nitro-methane or race-gas carries their own on-board oxygen-supply to increase octane-rating AND increase combustion speed for more power.
Or we can go back to basic physics, P=W/S or work/sec. Let's say you can lift 4-bushels of oranges into lorry in 4-seconds; you've generated P=4/4=1 amount of power to do this. Another bloke comes along and shoves identical 4-bushels in only 2-seconds. He's generated P=4/2=2 or twice amount of power. Things happening FASTER is what makes more power, not slower.
Here's some more info on octane, combustion speeds and power.
https://www.scribd.com/document/270451669/What-s-Octane <-- review references at end
https://www.caranddriver.com/feature...ar-or-premium/
https://oppositelock.kinja.com/the-r...ane-1785829176
https://www.2strokeheads.com/index.p...-of-detonation
https://link.springer.com/article/10...430-013-0094-y < -- really good
back-to-back dyno testing
https://nasaspeed.news/tech/engine/o...es-more-power/
https://www.hotrod.com/articles/fuel...ng-comparison/ <-- read last paragraph
https://www.hotrod.com/articles/0901...pump-race-gas/
In end, only difference between fuels of different octane-ratings is speed of radical-akyl groups formation during combustion. These are highly sensitive and unstable compounds that cause spontaneous ignition in areas other than flame-front, causing detonation & knock (pre-ignition is something completely different altogether). Higher octane fuels resists formation of radical-akyl groups better and their formation-rate is slower. That's where "slower" comes from since flame-front prop speed is exactly same 16.5m/s with same base petrol.
Old August 22nd, 2019, 07:44 AM   #21
I don't like E10, and will avoid it whenever practical, but it can make more power than regular gas. I didn't believe that at first, but it's true.
The caveat is you have to tune for it.
E10 will reduce gas mileage over standard gas in most vehicles, but it is cheaper, so it still may cost less per mile to use.
In this area gas without ethanol is about 10% more expensive than gas with, but gets almost 5% better mileage. Still not a fair trade-off, but I'll take it.
Old August 22nd, 2019, 08:32 AM   #22
Ethanol is... 115-octane, so it's potent octane-booster. Much better than those little bottles you get at FLAPS. I've been getting very good results with E85 on boosted vehicles. Downside is that -OH group in alcohols is HUGE and it displaces regular carbon & hydrogen. So you end with fewer C & H to combust per gallon. Automatic loss in MPG, -30% on E85.
Corn lobby is very powerful and they've been very successful at shoving their products everywhere through legislation.
Last futzed with by DannoXYZ; August 22nd, 2019 at 10:46 PM.
Old August 24th, 2019, 04:19 PM   #23
Bills dad
So that little turn knob on the left of the bike below the seat right above the chain sprocket cover what does that adjust on the carbs (if it's the carbs)
Old August 24th, 2019, 04:20 PM   #24
Bills dad
Just wondering if that will make it easier to adjust anything to the gas rather than taking the flaring off
Old August 24th, 2019, 04:53 PM   #25
The knob you're talking about is probably the idle speed adjustment.
Old August 24th, 2019, 07:40 PM   #26
To make any fuel adjustments, you really have to remove carbs from bike.
Most worthwhile changes require disassembling carbs and replacing parts.
Old August 24th, 2019, 09:33 PM   #27
Bills dad
Was afraid of that. I remember how much I enjoyed putting the air filter back on the carbs when I first got the bike!!!! Well before I go that route I suppose I'll see how this 87 runs tomorrow vs the 91 thank you again for all your input!
Old August 25th, 2019, 02:12 AM   #28
Ralgha
Ralgha's Avatar
You can do all the adjustments to the carbs without removing them. You'll need one of these. A mirror might help too, though I managed without. With that tool you'll be able to make all adjustments, including changing jets.
Edit: maybe not float levels, I didn't do that one.
Old August 25th, 2019, 07:09 AM   #29
Ghostt
Ghostt's Avatar
I've taken mine on long trips, it does just fine. The one thing that makes a big difference,is a better seat.
I have a Corbin, and it makes all the difference.
violente et ignorantia
ZX-2R BLOG
Old August 25th, 2019, 07:17 AM   #30
As TJ noted - that's the idle speed adjustment.
This section has more info about that and a lot more - https://faq.ninja250.org/wiki/Intake
Old October 17th, 2019, 06:20 PM   #31
Bills dad
Thank you for all your input! Sorry been a while to respond, life happens I suppose, been using what they call clear gas out here in Nevada at the maverick and 2 full tanks later she runs better and fuel lasts much longer suppose to have no ethanol in it, she's happy so I'm happy. I have that right angle tool so will keep that in mind, and I will be looking into a corbin seat very soon as I moved 20 miles out of town now as the stock one just ain't cutting it !
Old October 17th, 2019, 09:14 PM   #32
You can also use screwdriver like this. I'll spin down handle so it's narrower to give me more room.
Also would be good idea to run through fuel-system cleaner with healthy dose of PEA. Does really good job of clearing out dried petrol varnish and keeps carbs clean.
- Red Line SI-1
- Techron Concentrate Plus
- Gumout All-in-One
- 3M Max Strength Fuel System Cleaner #08814
- Royal Purple Max Atomizer 18000
Old October 17th, 2019, 09:33 PM   #33
Kevin1956
Kevin1956's Avatar
An hour on the freeway isn't all that much, but I would suggest going up one tooth on the countershaft sprocket for riding at higher speeds. These things are geared a bit too low. One tooth isn't a big difference, but at higher speeds it takes out some of the "buzziness" as it lowers rpms slightly. One tooth won't require chain replacement either. In-town riding also benefits, as you'll find yourself shifting less often in stop and go traffic. I find this slight gearing change makes these bikes much more enjoyable to ride overall.
As far as gas, mine seems to perform better and definitely gets better mileage on the lower octane stuff. There's about a 5 to 8 mpg difference! I believe the owner's manual recommends lower octane also.
Last futzed with by Kevin1956; October 17th, 2019 at 10:39 PM.
Kevin1956 is offline   Reply With Quote
What is the Lincoln Highway? Kevin1956 Ride Reports 9 July 22nd, 2015 01:53 AM
I did it again.... (on highway 9....) Jiggles Videos 27 June 12th, 2013 02:12 PM
First highway ride? Bigballsofpaint General Motorcycling Discussion 2 May 11th, 2011 03:47 PM
Went down on the highway djindia23 General Motorcycling Discussion 25 August 18th, 2009 02:59 PM
Highway 1 Lurkable Ride Reports 9 August 10th, 2009 10:59 PM
