March 25th, 2012, 09:50 AM | #1 |
Join Date: Oct 2011 Motorcycle(s): 2008 ninja 250r Posts: 7
Starter Problems
So, I still have not had any luck with the starter. I noticed today that when its cooler out the bike with make a terrible clacking sound when pressing the starter. However, as the weather warms during the day, the bike will start with minimal noise from the starter and runs like a charm. I still have not been able to pin point the cause yet but I'm hoping it's nothing too expensive as I was just about to put it up for sale.
March 25th, 2012, 03:54 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
Have you tried removing the starter and cleaning it check its bearings ,brushes etc
Be safe ride smart .....a dumb rider is a dead rider |
March 25th, 2012, 04:00 PM | #3 |
Join Date: May 2011 Motorcycle(s): 2002 ZZR 250 Posts: 127
When its hot out things expand making loose things tight usually. Hence why the sound goes away. I had a clacking that sounds like a chain hitting and my cam chain was done along with my main bearings.
Take a Spoon hold it to the engine when you hear this and you can pin point it by moving the spoon around |
March 26th, 2012, 01:24 PM | #4 |
So, I went to start it today after it was baking in the sun, and when I pressed the started button the starter motor just spun. It would not catch to turn the engine over anymore. I think I may try taking the starter motor off and seeing if its just that. I'm hoping the gears are not stripped.
Starter Relay/Starter Problem | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 13 | July 13th, 2012 05:02 AM |
